My reverse lights don’t work. There was only one fuse blown in the car and it was a/t control fuse what ever that is but I replaced it Incase it had something to do with it and they still don’t work.
i then checked the globes and they look fine, just a bit of rust in the plug the globe sits in. I then checked to see if power was getting to the connector in the boot and still nothing. So I believe it’s the reverse light switch, however I can’t find it. Is it on the side of the gearbox or is it built into the auto selector? Can anyone guide me in the right direction please.
thanks
1 hour ago, GTSBoy said:
a/t means Automatic Transmission. A good clue that something is f**ked down there. You don't blow fuses for no reason.
Have you tried searching for "reverse switch auto" on here?
Previous owner did a trans swap because it was bad so I’m assuming/hoping it blew from the old one. As for searching on here I can only find things relating to people doing auto to manual swaps and having trouble with wiring. All I really want is just to know where the location of the switch is so I can test it.
14 minutes ago, Rusty Nuts said:
If you had just followed the advice that GTSBoy had given you the fourth entry of the search gives you the answer.
The fourth one for me shows a guy wanting to connect the wires from an auto box look to a manual box. Is the plug in a different location on the automatic transmission and is the trans the same on the r33 as the r32? If that’s not the right one could you link me the one you are talking about?
I still can’t find this stupid reverse switch. I did also find out it has 5 gears which makes it a Re5R01a, not sure if that makes a difference in the location or not but there is very limited info on this so I might just end up taking it to a professional seeing as how retarted I am
3 hours ago, GTSBoy said:
I would strongly suggest, that like most early automatics, the reverse switch is bundled up with the inhibitor switch in the shifter.
Like as in it’s inside the car? Not under or screwed in the side of the trans?
This is why my fuses kept blowing. I ended up putting a bigger fuse in and ran it until something started smoking, And well the dash is the last place I expected. I replaced the part as I was lucky enough to have a second one laying around. Everything works fine now.
Edited by Steem
As a diagnostic tool, despite it revealing your problem, I find it horrifying.
Yes I agree it’s not the best way but I have spent too long trying to fix this with little tools I have. It was a last resort. But I also want to thank you for your help with both problems I have posted here, I really appreciate it
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
