If it’s been wired to 12v will that have f**ked the sensor?
as I’ve tried changing the wiring to suit as per above, so wired black to yellow and white to green.
or have I messed that up (I’m terrible with wiring it’s my number one hate 🤣)
Hmmmm not sure, but an assumption is maybe.
A reluctor creates its own voltage so you don't feed it one.
Aye probably dead then 🤣 will probably just pop the stock CAS back on.
i do have the paper wiring diagram with notes on it somewhere so I’ll cross reference that first
Maybe find the spec sheet and see what the resistance of the coil is, possibly it's not fried? Especially if you didn't short it
maybe another thing for me to try? timestamped (i know its the nz wiring kit, but this is on the haltech software side)
You can just swap the pins at the CAS connector side.
You could go old school and use a test light to see which pin is going back to B1 on your ECU
I ended up trying every pin combination. got the car to start once, then rev'd it and it died. then couldnt get it started again.
Threw my toys out the pram and put the stock CAS on and it fired first turn of the key (with backup map reapplied)
I'll re-visit it another day when i get the motivation again.
sounds like you are super close, either the air gap is out OR the trigger arming voltage is too high.
In NSP, just plot the trigger voltage vs. RPM vs. time and when you crank it you'll see what it reaching, adjust the trigger arming to suit
next time i have a full weekend i'll have another play, currently one month away from wedding so have no free time...
Thanks for the pointers though,
Don't buy a Tiguan :D
I'm from the UK, everyone knows you buy a Seat or a Skoda as they generally run better than their VW / Audi Brothers 😆
  • Haha 1
Lololol... Funny between brands reliability changes, yet it's technically the same parts.
  • 10 months later...
55 minutes ago, shortyboy said:
any update on the yelsha-d trigger setup? Looking to get one for my neo on link g4x
No sorry mate, I gave up on it, also sold the car mid December and recently replaced it with a BYD Shark / Temu Raptor
  • Like 1
Aye I know, moving interstate, have to give up the work vehicle so replaced it with something “sensible”. Fastest Ute you can buy for under 250k 🤣
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
