I have a shop currently finishing up work on my R32 GT-R and part of that is retrofitting an R34 AC compressor so that it can run R134 but we need the correct lines to complete the job. If anyone here has a pair of high and low pressure AC lines for an R34 GT-R I would really appreciate it if you could get in touch with me. I'm located in the US but would gladly pay the shipping. Even a set of cut lines will do as long as the end fittings for the compressor are intact because the shop says the can refurbish the lines themselves but need the fittings to properly fit the compressor. Thank you in advance for any help.
https://www.sau.com.au/forums/topic/480037-need-r34-gt-r-ac-lines/
5 hours ago, xensor said:
Can you give me a specific part number?
otherwise I cant ask the guy.
Sure, they're 92480-AA400 or AA401  for the low side hose and 92490-AA400 or AA401 for the high side.
Hi, me agian sorry for the delay. it seem like low pressure one are out of production now.
switch whole a/c compressor might be a better idea.  I mean finding 34 part is going to be a giant pain.
https://www.amayama.com/en/part/nissan/92480aa401
Surely the ends are common with a millionty other Nissans of the same era? Just buy something with ends that match the compressor and cut them and your old ones up and get someone to weld them together with new hose as required. That's what I did (admittedly with R34 Neo compressor ends) onto R32 hoses when I did my transplant.
Thanks for the replies everybody. The shop informed me this weekend that they were able to source a used compressor with lines from eBay so we're waiting on that and hopefully that will bring the search to an end. I'll post again if we're still not lucky but in the meantime take care and stay healthy!
    • That seems like a very special issue!  Does it affect both sides? Either way, I would disconnect the driver's side switch and see if it still happens, noting that might require removal of the whole door card which is a bit of a pain (it does on V37 and HY51)
    • MBS206:- The windows start to slowly open themselves. GTSBoy:- Battery is new since Dec.
    • I currently have a 2008 370GT Coupe, with the big brakes (Akebeno if I'm correct), and Its coming time to get new pads. Previously, I had a 2003 350GT Coupe with the stock sized brakes, not Brembos. I had custom wheels on it that were pretty open to the brakes, and when I first put the wheels on it, the rims where completely coated with brake dust. A few years after adding the new rims, I needed to change to pads on that car. I didn't do any research, but I told the mechanic of the problem with the brake dust. I also told him I didn't track the car or even drive around the streets harshley. But the dust was an issue. The mechanics changed the pads to a different compound, and the dust was GONE! The other change I noted was that when coming to a complete stop, instead of having to press harder on the pedal as I approached 0kph, I had to actually lift off a little to not come to a hard jerky stop.( My unfounded explanation is they became stickier as they heated by stopping ) Since I got my 370gt with big brakes, I noticed that that as I came closer to stopping, I had to press harder and harder to reach a full stop. I am not talking about hard, just harder. I brought the car in from another state, so when I had a blue slip done, I asked the mechanic what he thought of the brakes, and he thought they were brilliant. The only negative of these pads on the 350GT, was that they squealed when cold. So driving out of a shopping center carpark, it was a little embarrassing, as the brakes squealed, and I am sure people thought that I needed new brakes, when they were actually fresh. I have no idea of what type of compound they were on the 350gt, but whatever it was, I want to get the exact same on my 370GT. They weren't ridiculously expensive, and were replaced at the local JAX (which is no longer open), so I am certain they would be a pretty common big brand, off the shelf type/brand. My current mechanic suggested I need top get the rear pads changed soonish, but he suggested standard Brembo pads. Which I expect to behave the same as the current ones and not like the ones on the 350GT.  I don't think dust will be an issue on the 370GT. With the behaviour I describe above on the 360GT, does anyone have a suggestion of pad material that will act like the change I had done on the 350GT?
    • The consult isn't even OBD1. It's a Nissan Consult. Proprietary.   Re read everything I've said. I specifically say, put down the laptop/tablet. Understand, and review the issue first. Logging voltages is the same as logging the converted value. Things like O2 that you say to log, is unusable for this, whether it be the voltage, or the value the ECU thinks.   The fact you don't know how to diagnose without looking at the computer, is exactly what I've said multiple times is the issue for why techs these days can't diagnose the fun issues with cars.
    • Breather for it. If it's anything like the GTRs it should run up to the top of a bellhousing bolt.
