So I've been serching the forum for a thread on how to test if the check engine light IS working.
Some back ground, I have a engine harness from wiring specialty for a S14 chassis from the previous owner, the R33 RB25DET S2 is going in to my 280Z but I can't seem to find a connection off the harness for the check engine light, the wire is there but I'm not sure where they (wiring specialty) terminated it.  I also installed a DZ-START that has a Nissan maximum push button start. So off/acc/start.
So going off the pin out for the stock ECU that I have, it shows pin 32 so I spliced into that wire with an LED and grounded it. (Note: wire color indicates Orange/black but wire is only orange)
Now the problem, maybe. When I start the car the check engine light comes on but for a split second, not as long as most cars do. (If you're not paying attention you will miss the light thats how fast it is)
So to the point, is there a way that I can test to see if the check engine light is working correctly. (Yes the light itself works) or is a LED not the right choice or do I need a capacitor to prolong the light?
Thanks
https://www.sau.com.au/forums/topic/480043-is-my-check-engine-light-working/
hmmmm, have a look in the r32 gts manual and see if you can find something in the wiring. I know for my r32 gtr rb26dett I have the bnr32 manual and everything for wiring from what ever is in there. might be able to get some info there...any pictures of the splicing would help too...I know to check engine codes on a gtr you just need a paper clip and theres a spot in the fuse area you just arc. but I know your not checking codes but this may be a way to check to see if its working as well, may be different for rb25 tho..
Take the dash out, check the globe directly.
Then power the globe from the terminals on the loom plug on the dash.
That will tell you if it's all good up at the dash, or not. And there is little chance of it being broken anywhere else, unless some twatbasket has cut the wire at the ECU.
This engine is in a Datsun 280Z so I dont have a dash loom, just the engine loom and no R33 fuse box. Yes I have a fuse box from EZ-WIRE and have spliced in the specially wire loom. I'm going to wire a capacitor on the LED to see if it stays on longer during cranking.
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
