Hey guys,
I’ve got an manual R34 GTV (the GT model with factory gtt lsd, brakes, suspension).
I’m looking to do a RB25DET neo swap.
I’ve heard that the GTV only came with the RB20 box like the GT’s, so I’ve already swapped in the RB25DET GTT box with a new clutch.
The RB25DET I’m looking at comes with complete hot and cold sides, ecu, engine loom and alternator. Is there anything else that I need to complete the swap?
Thanks
https://www.sau.com.au/forums/topic/480044-rb25det-neo-swap-in-r34-gtv/
15 minutes ago, GTSBoy said:
Make sure the ECU boost sensor is on the loom.
Upgrade the fuel pump.
Nothing else that I can think of.
It is quite possible that the TCS won't work properly. If it doesn't and you end up with codes, you will need to Nistune the ECU. Should do that anyway.
Thanks, makes sense.
The car didn’t come with traction control, which is a bit confusing but at least it makes it easier.
What’s a good fuel pump to go for?
Cheers
That's the problem. The car doesn't have it, the ABS/TCS CU is probably only ABS enabled, and the ECU expects to talk to the ABC/TCS CU about both ABS and TCS. It (the ECU) will probably chuck a spaz. Hence needing to Nistune to sidestep the codes.
Bosch 040, Walbro 255, or anything newer, bigger and better able to take ethanol than those.
ahhhhh I get it.
thanks heaps ??
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
