Hey guys I've had a problem with my r33 for a while now, If the engine gets hot  (on a cold day this wont happen unless the car is thrashed) it will stuggle to idle most of the time resulting in it stalling when not under load but if I put the ac on it will idle at the normal range for about a minute then go back to stalling
Edit: If i change down gears slowly it will not stall when i stop, But if i suddenly press the clutch or put it in netural whilw stopping it will stall also the car does not have an afm
Edited by Lockyb123
https://www.sau.com.au/forums/topic/480051-r33-rb25det-idle-issue/
 Yeah mate it's got a stinger ECU but I don't think that's the problem because the cars had this setup since I've owned it and it started having this issue about 6 Months in to owning it (also had a tune from a well respected tuner in my area since which did not fix the problem)
I had an issue like this on my rb26 was iacv valve was right plugged up and caused the engine to stall when turning, lights on, a/c on etc. I don't know about your rb25 but could be the case if it idles fine when cold. also theres a screw on rb26 iacv that you can adjust I don't know about your setup but have you tried turning up the idle a bit in someway either through ecu or manually? what does the car idle at on a cold day when warmed up?
  • 1 month later...
    • From when I was looking at getting the 86 engineered for the turbo, the joint said to put in a few euro 5 or 6 cats, then tune the car on a nice clean E85 tune When I was looking at a turbo for the MX5, it was basically the same thing, a couple of cats and a nice clean tune Although, it will depend on the year of the Jeep IRT emmisions standards required, and what mods are done, especially if it has a newer engine installed that requires a higher Euro
    • Yeah - but it's not actually that easy. There are limits for HC, CO, NOx and particulates. Particulates shouldn't be a concern in any petrol engine unless trying to comply to the very latest Euro standard. But getting a tune right so that all the others stay within limits AT THE SAME TIME is not a trivial exercise. You couldn't possibly get it right by just guessing at the tuner's dyno, unless he had a 4 gas analyser up the pipe, which is not often the case these days. It used to be. Every decent shop that did "tune ups" (as opposed to tuning) would have a 4 gas analsyer. Perhaps there's still quite a few of them around these days. But most "tuners" are only watching O2 and power readings.
    • Slight segway but the most expensive part of the whole thing which I would have thought would only be required for an engine size/type swap, not a VIV test, is emissions testing.  That's when you get into the big bucks.  I can't remember the exact price now but I got quotes for the GT-R based on swapping to RB30 (not that anyone bothers doing it legally anymore...) and it was around $4500 just for that alone.  The guy that does them manipulates the tune on the vehicle to make sure it passes.  The cheaper option is to book into Kangan Batman Tafe (I think that's where it was) and hire their tester.  Allegedly you're not allowed in there with the car though so not in a position to tweak anything to make sure the vehicle passes.  I'm sure in this day and age of ultra tuneable ECU's you could get the tuner to program a special efficiency (clean) tune that emits the lowest amount of particulates possible that would pass the test.  It might only make 50kW's but as long as it passed who cares!
    • I'm sure he has left signs, or, he is looking down, laughing That's my cunning plan for when I leave, lots of half finished projects, with no rhyme or reason of where I was actually up to, just to keep everyone on their toes
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
