Hello,
I have a R34 GT and my brake pedal has no pressure. I have replaced my master cylinder with a used one from Ebay and same result. When I pump the brakes it hold pressure for a few seconds with car on.
I can only find refurbished parts, is there a way I can use new brake master cylinder from another vehicle?
Edited by skylinebey
https://www.sau.com.au/forums/topic/480073-r34-gt-master-cylinder-replacement/
If you take your M/C to a brake specialist they should be able to repair it with new seals. If it is badly worn and pitted they can resleeve it. If you can find a new one it is likely to be up around $400 -$500.
Have you checked out the supplier below? They have a couple of items they say will fit the R34.
https://www.ebay.com.au/itm/OEM-QUALITY-Brake-Master-Cylinder-For-NISSAN-280ZX-S130-Part-JB1362/172450975591?fits=Plat_Gen%3AR34|Make%3ANissan&hash=item2826e10f67:g:KmcAAO
Or try Amayama...I have previously bought an R33 M/C from Nissan in NZ but I believe most Aussie dealers will not get one for you.
Thanks,
This is my second refurbished MC from eBay and same result.
I tried the mechanics here and they don't have any repair kits.
So I will have to look on eBay for a resLeeve kit.
Does the brake booster go bad?
If so, how to I check ?
Thanks again
13 minutes ago, skylinebey said:
Thanks,
Thanks again
The one I listed is supposed to be brand new, not refurbished. Your average workshop will not do the work -  you need a brake specialist. You will  not likely find a kit on Ebay.
Brake boosters can fail but you would have the opposite problem - a lack of assistance, not the pedal sinking to the floor.
Have you checked each corner of the car for leaking brake fluid?
Don't buy "refurbished" MCs from eBay.
You don't want a kit. You don't want a mechanic. You want a brake specialist, exactly as Kiwi said. You take YOUR MC in there and they fix it, and they give you a warranty. If you take it home and install it and the pedal is still f**ked, it is very much more likely that you've got another problem, not that the MC is still faulty. And then you start to think about your caliper seals, etc.
They can and do, but that leads to a hard pedal, not a mushy pedal.
I have replaced the original calipers with the upgraded calipers from the R34GTT model mines was the GT  NA.
Presumably with used units. You need to check each wheel.
Another possible source of  new M/C is Kudos Motorsport.
I presume you have replaced the old fluid with new and properly bled the system?
The old caliper had a frozen piston and rusted .
I cleaned up the piston and resealed that caliper and the brakes became spongy.
So I then replaced with the bigger Gtt calipers and
Pedal was still spongy?
I then checked the Gtt caliper to see if there was a leaky seal. The was no leak.
But still spongy , Then I thought the larger caliper working with the original MC was causing the spongy .
So thats how I got to the MC being the problem... because it happened when the Orignal caliper went bad.
I even replaced the ABS unit. Still same response.
8 hours ago, skylinebey said:
What is the proper procedure bleeding with a dry ABS?
Thanks.
Sorry I don't know. I have always made sure to keep air out of the ABS unit. Some cars have small bleeder screws, some need a pressure bleeder and for some you need a scan tool to open and close solenoids. The answer may be in the workshop manual or hopefully someone else may be able to help.
I am 100% sure that the procedure for bleeding the ABS has been posted before. Search, and ye shall find.
By the way, it is a complete prick of a task.
Also, when it comes to (vital safety) stuff like brakes, if you really do not know enough to solve your own problems, you should really consider using a professional to fix them. Just sayin'.
My experience is with R32 GTR, being 10 years newer there may be easier ways to do it in an R34
It is a complete prick of a task.
Ultimately I pressure bled the system - 4 calipers (8 nipples), in order of furthest to closet to the master cylinder (so RR, LR, RF, LF) and then the 2 nipples on the top of the ABS.  Of course, since there was air in the ABS unit it was unsatisfactory, and since this was happening during a rally I needed to deal with it. So, after each stage I bled the ABS again (during the stage each time you trigger the abs all the little solenoids and things open and close moving air through the system).  Still sucked. After the event I then did a full bleed and it came up good
So, pressure bleeding makes it much easier because a single person can do it with less effort, and the ABS didn't come good simply by bleeding it static, it needed to be cycled a whole bunch of times before the air all moved out.
Hopefully R34 has some sort of ABS bleeding mode you can put it in instead of having to drive it and activate ABS over and over again...
Thanks
i live on an island , finding mechanics that specialize in just brakes is difficult. So you learn how to do things yourself. I practice safety that is why the car has been parked for almost a year now.  I will not drive it until this issue is resolved the right way.
I have a brake vacuum kit to assist with the bleeding of the lines.
I have a software to run diagnostics on the car I will see if it has the ABS troubleshooting.
I will try as you recommended. Thanks again, like I said earlier specialized is hard to find.
I appreciate the time you took to help me.??
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
