So.....
After parking my 86 into a fence, and then a guard rail..?..I bought a old Bogan 2002 VX SS II auto cruise ship for a daily driver/project.
Enter 1 x 2002 VX SS II Auto
1197609157_59a33d64149a4f7c3a7d1f8e6141c9a0(1).jpg.c8894ac19d8fb5c16774a26b3441dd31.jpg
I searched around for ages looking at everything from new MX5's to 370Z's, and everything in between, I came across this old boat early in my searches, the boy pointed it out actually, he said "it looks old, slow and noisy, just like you, and mum would hate it", so with that kind of endorsement, and, with nothing else that really touched my special spot (something different, something I can play with, something that should annoy the neighbors and old peole, something with minimal electronics that a old idiot with monkey fists can work on, and parts that are easy to find and cheap, and parts that are cheap, and parts that are cheap), I grabbed it.
Don't ask what I payed for it, I'm pushing that bit of information back down deep into my brain where my empathy lives to never surface again.
Needless to say it is super clean and straight.
Engine: LS1 5.7
Headers, twin 2.5" exhaust, OTR, Tune??? (It goes surprisingly well, LOL, shut up, it does go well, and it sounds f**king awesomeballs) it will visit Pulse Racing for some love in a while.
1464878211_4dfc62148ab2810de94a8dd2977d107a(1).thumb.jpg.de764504cd2683562f1f4d192411250f.jpg
I'm not sure about the Simmons rims though, 18 x 8.5 with 245/30 front, 18 x 9.5 with 265/30 rear, I think I'm going to try and find some OEM VX SS rima for it (swaps????).
Suspension:
Yellow lowering springs (Kings?).
Some shocks??, I'll have a better idea when I lift the car and pull the wheels.
I'm thinking its had some bushings done, the thing is as tight as a tiger.
I've only just got it, so, so far I have only cleaned the airfilter, it's a over the radiator CAI jobbie that makes cool induction noises.
So far things to do:
Engine oil and filter
Spark plugs
Trans flush and filter
Diff oil
Brake fluid flush
Power steering flush
Coolant flush
Wheel alignment
Good wash, polish and wax
Wrap headers.....maybe, or find some other form of heat sheilding for them...
Then, look for other stuff like old hoses or broken stuff.
You know there will always be broken shit in a 20 year old car.
What are my plans for it? drive it around really, hit the drags once or twice for some LOLs, not back it into a fence....and guard rail....
df177104d259972fc255ce32db30dd44.jpg.49fef929073a0f40cf0623934b2ecbe4.jpg21d7fa56e5065b02cce73f9adbd14eca.jpg.f92c054feebc2b02b8b4348a88a95281.jpg4112fdfedd7fffe90facbae3d90e878e.jpg.a7926f6fff584b1a38cd6790e9db8e40.jpg168cfa4423c5790cadaa17c6e0118049.jpg.0e6be2abfcfe3e7c47328e59751c9b53.jpg
  • Like 5
https://www.sau.com.au/forums/topic/480074-mlrs-bogan-cruise-ship/
2 minutes ago, r32-25t said:
This is a surprise, I was expecting a ve/vf
I was going that way, buy this "looked" cooler to me.
Plus it was 1/3 the price of a VE - VF with simular milage and mods.
And at only 100k km, with full log books, and a country car, the condition was hard to pass on.
  • Like 1
2 minutes ago, Ben C34 said:
Oh yeah! Now you are talking.
Get a new plastic power steering resorvoir, they are cheap as and then you get rid of that yellowy plastic crap.
skid vids please
Yeap, and the coolant one as well.
Lots of reciepts
Pacemaker headers and exhaust - 2016
VCM OTR - 2016
Tuned by "Oztrack" - 2016
Rebuilt diff 3.9 gears - 2016
Rebuilt transmission - 2016
New radiator - 2018
New T2 DBA rotors- 2018
Bushings - 2018
Lots of servicing and maintenance.
History looks to be 1 owner till 2015, then next owner proceed to throw cash at it.
From the googles it "should" be around 220ish kw and 500ish nm, I will see what it really is after I service it and it gets on the dyno.
  • Like 1
22 minutes ago, Dose Pipe Sutututu said:
People usually start with Commos and end up with mature sports cars.
But you, lolwtfbbq
They say when dementia kicks in you revert to your younger years.
But then, I've been demented all my life.
In other news, the battery has passed the trickle charger test and will sit on charge for the night.
  • Like 1
23 minutes ago, mlr said:
It also passed the speed hump test heading into work, thats a bonus.
Naice, what sort of headers? Tri-y's or 4 to 1?
I had a VX II Clubsport at stock SS FE2 height it used to scrape at speed humps with 3" 4 to 1 headers lol
I sure do miss the noise, especially when a mate decided to take the exhaust from headers to back out at 10pm and then started the car...
But you, lolwtfbbq
Ain't nothing wrong with maturity to immaturity.
Tri-y's
Good for daily abuse.
Response is instant ?
21 minutes ago, Count Grantleyish said:
Excellent choice from previous owner.
Edit: I thought you said you were the previous owner, I then started to ramble and quiz for info....my comprehension kung fu is weak.
Apart from the broken passenger door handle...I was trapped in the passenger seat for a minute or 2 this morning, I assume it's rhe plastic linkage thingie, or hopefully, a circlip.
How does rear main seal look?
Power steering pump?
These two are most common things that leak. But from the receipts above, looks like it's well cared for example.
Rear main has a reciept from a couple of years ago.
There is some sweating around the pump, not alot, but enough for future investigation.
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
