I've got to stop googling because.....
https://www.oztrack.com.au/index.php/2013-09-27-06-14-12/performance-camshaft-information
3. HPA/HP2- low 230s cam, lumpier and more up high power by a small margin over the LSV calmer than the GT. Biggest recommended cam in Automatics.
6 hours ago, Kinkstaah said:
That dyno graph will not be for a 5.7, fyi!
Yeah, I assume there is more to that dyno than a cam and some bolt ons.
From searching around a cam that suits my auto might get me a bit more up top but a good chunk in rhe middle without sacrificing to much down low, where rhe 3.9 gears should help anyway.
My power will be limited by the cam I am able to use with the stock converter.
The car is currently a daily/cruiser, the 3.9 diff has me reving pretty high, even in top gear, when doing 110, hence, I cannot fit a high stall to suit a big lumpy cam, and not kill the converter.
Compromise is  my middle name.
Anyway, that is what I'm rolling with ATM, I'll talk to somw SME's on it and see how I proceed.
The thing about cams is there's really very little "just better everywhere" cam.
Consult SME's at Ls1tech.com or give VCM a call and tell them (honestly) what you plan on doing with the car in entirety and they will be able to sell you a kit
  • Like 1
  • Thanks 1
Generally, more lift with a wider lobe nose but no increase in total duration is the best "just better everywhere cam". Harder on the VT of course, but something has got to give.
  • Thanks 1
1 minute ago, Ben C34 said:
get a 3500rpm converter. do it properly.
My understanding is that the correct RPM range for the converter should be 500 RPM below the cruise RPM IOT ensure the converter has stopped slipping.
Back when Mosses wore shorts I remember guys throwing in high stalls in their street cars with varying results of reliability, due to the converter constantly slipping and cooking.
Disclaimer: I'm far from actually knowing what I'm talking about, my memory is a bit fuzzy, and the googles is full of misinformation.
I'll give VCM a call and also pop into Oztrack in the Riff for a chat.
Oztrack did the original bolt ons and tune.
34 minutes ago, GTSBoy said:
Big transmission cooler.
Don't these things have an electronic lockup anyway? So when cruising that's in charge, regardless of whether the converter is in the slip range. Amiright?
correct. it isnt 1985 anymore.
  • Haha 1
Hey, I was 20 in 1985.......
Good times were had, I think I had my LJ around then.
Ahhh, fond memories of drag meets at port botany on Saturday nights.
In other news: I really need to research shit more.
  • Like 1
On 27/04/2020 at 1:05 PM, mlr said:
I'm thinking a bobber type build, I'm to old and arthritic for a sports bike.
Maybe a Triumph Speedmaster bobbered and murdered out.
Fark, who am I kidding, It could end up being anything.....
I’m a fan of the matte triumph scramblers personally.
Now you cannot see the butchered air cond heat exchanger.
I used some pinch weld I had laying around, it ain't pretty but it works, I may try some different pinch weld next time I'm near somewhere that sells it.
Radiator should be a bit more efficient as well, I'm guessing, as I'm not lossing air pressure in front of the radiator due to the air bypassing the radiator and entering the engine bay up and over the top.
  • Like 2
Back on the more loud and obnoxious train of thought I have a lingenfelter 2 step for sale at the moment. It is the Lnc-003 that has 2 limiters, the lower limiter is activated when you flick a switch. Plugs straight into coil loom in minutes.
Was used to make boost at drags on the line (manual box) however is also pretty fun for shits and giggles, so I thought of this thread! Otherwise will put in ebay. 200 delivered
Spam over.
Spam over.
Whilst I do love a good 2 step, yeah nah, #becauseslushbox
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
