Got my quote for a cam and stuff install.
Waiting for workshop time now.
oztrack-camshaft-kits-with-remote-custom-tuning-afm-delete-removal-cam-upgrade-online-leaders-in-ls-auto-part-tire_709_250x250@2x.jpg.4657e7a70c1e18cef044f9f6ef46454a.jpg
Cannot decide on which one though.
Oztrack recommend the LSV or HP3.
They recommend that LSV would suit the car as is, but the HP3 has headroom for intake manifold and head work in the future.
LSV idles smooth and comes on fairly quick.
The HP3 is fairly choppy (I love the sound of a lumpy cam) but still ok for the stock converter.
Both are a big improvement over the current cam, lots of gains in torque and between 30-50kw up high.
I'm leaning towards the HP3 maily because of #lumpyloapylols, the 3.9 diff gears should "hopefully" help it get up into the cam without to much delay.
Streetability for both are apparently good.
Hmmmm
In other news: my fears of a highstall and not locking up in the auto are unfounded, soooo, if I do go the bigger cam, a high stall converter will be the next mod.
Now all I need is that WSID opens soon so I can do a pre and post run.
LOL, f**king Covid spoiling all my fun.
Hmmmm
LSV out of those choices. THe LS1 doesnt need / beneift from such a large exhaust duration split.
choppy idle can be tuned to suit.
glad you have seen the light regarding conveters!
  • Thanks 1
You are going to run into the exact same problem I did re: Cams and the rest of the system being able to supply the air the cam wants.
Be aware!
If you are going to keep stock heads (and not be super obsessive about checking springs, etc etc, want something that will be put in and forget) then the LSV is the smart choice.
The "power" category of that chart does require additional mods to unlock the said power. Drivability is easier in an auto which you have on your side. Cam surge is just shit to live with. Power under the curve is still a thing in V8 land.
  • Thanks 1
Be aware!
I've been looking at heads and an intake, the intake is relatively cheapish, the heads are costly, sooooo
Thanks all for the information, I'll have them throw in the LSV with the all the other snot they install at the same time.
It is diminishing gains (especially value for money wise) when going further than just a cam / spring job.  As kinkstaah said area under the curve is still important, and going to a larger can will hurt economy also
  • Thanks 1
Car goes in tomorrow.
The guy recommend trunion bushing kit?
They look like solid brass vs roller.
Like this > https://vcmstore.com.au/products/ls-rocker-trunnion-upgrade-kit
Thoughts
Thoughts
Wrong part number and link for nitrous kit
  • Haha 1
Thoughts
I vote no. I would be more concerned the trunnion galling when solid, considering the way they are lubricated is "hoping the oil splashing around happens to land there", push rod style! .
  • Thanks 1
Its less choppy than mine. That said it probably drives right, and doesn't shake you and your passengers at idle in the seat (is kinda cool tho) and is the right cam! Which one did you go in the end?
LSV
It does do a "little" shimmy at idle in neutral, once in drive it just squats down a bit harder on the brake.
Thats really what you want man.. Idle shake is cool and all until you have anyone in the car that doesn't think its great and it quickly becomes shitty.
That cam looks the goods. Was the dyno run locked?
So, after taking the Mrs for a cruise today (Robertson pie shop, long way there, long way home) I'm definitely looking at those interceptor copies in silver, with caps of course, #fullbogan
17 x 8 + 42 for the front
17 x 9 + 48 for the rear
Tyres will be Hankook RS4, cheap but good.
235/45 front and 255/40 rear
Rollin' on 19" rims and rubber band tyres is arse on anything other than dead flat and smooth highways.
I'm just waiting on a shipping quote.
In other, Mrs related news, she wants me to put the pacemaker rear muffler back on, doing a dollar ten on the highway with 3.9 gears is to noisy for her to sleep.....LOL.
Meh, things you do..
I'm also still looking for 2 interceptors, 15 x 7 which I will shod with some Micky T's for LOL's at WSID.
I believe the converter was locked.
But, my speedo reading is way out now, I believe they f**ked up the calibration it had for the 3.9 diff when they played with rhe tune.
GPS reads 80, speedo reads 100.
How and if this effects anything I have no clue, apart from me driving like Miss Daisy.
I'll ring them tomorrow to get it fixed.
I was doing what I thought was 100 in a 100 zone and everyone was passing me, I got the Mrs to get google maps up and to my dismay I was doing 80.
    • No intention of driving the car the way it's set up now, just wanting to make sure I haven't made any mistakes along the way so that the tune can go smoothly, I don't want to waste anyone's time with stupid issues. And of course I intend to get it towed to the dyno in a completed state 😅 I have the base fuel pressure with the vacuum disconnected set at about 40psi, which I believe is at least relatively close to stock fuel pressure, maybe I'll have a fiddle with the reg and see what happens. For all I know I could be wasting my time with this and I should just plumb it in and see what the tuner reckons. I just find it a bit strange that it seems to be under so much load just free revving, but maybe that's just a result of the turbo slowing down the exhaust gasses and making a restriction in the flow, with no boost to compensate.
    • The boy just hit up google translate and it worked a treat, he said step one was "please urinate with precision and elegance", he then sent me the correct translation  I get some new loctite for the small fixtures tomorrow and get some "dort" going after that 🤣
    • Right, so is the fuel pressure the same as it was previously? If not, well, it's not going to work well. I can understand the theory I assume you are going for, which is: "Run it N/A, and if I have the original AFM, and same amount of fuel and intake air as previously, the fact there's a turbo in my exhaust should still make it run" Which it... might? Provided you don't actually change how much air or fuel is going into the car.. or getting out. But if you have changed that, all bets are off. What is the purpose to even have the car run this way? To get it to a tuner? And if the goal is to limp it to a tuner, you're still going to what - plumb up a whole intercooler system and new intake in the parking lot out front before your tune......?
    • Haha yea it's a bit of a weird setup at the moment, just wanted to make sure I sorted out any headaches before dyno day. At the moment I've changed the exhaust manifold, turbo and downpipe, 460lph fuel pump and rising rate reg as well as the previously mentioned headstuds and gasket. The nistune was already mapped for the car as it was and drove around for a few months no worries. The plan is to run flex fuel hence the big pump, which I've wired direct to the battery through a relay to avoid voltage issues.
    • Um. Was the ECU the same as the one previously there? I know R33's needed R32 GTST ECU's or other tomfoolery to run Nistune. This is such a wild setup. Most people would plumb in the turbo then not drive the car (i.e tow it to a tuner). What's actually changed since it last ran?
