On 2/3/2022 at 10:14 PM, mlr said:
The car is a great place to be in cruising along, inside the cabin you can barely hear the growl of the engine
Shame, you should give up and buy mine instead, barely hear the engine? What kind of build is that. Why isn't it offensively loud until you drown it out with the stereo till the point you cannot use your rear vision mirror anymore? (but somehow quiet outside the car)
  • Haha 2
Slightly less bogan without the reverse cowl
Paint match of the bonnet and front bar by Fineline is spot on, again
Also sold the old bonnet with the cowl pretty much straight away, which was nice, as it triggered me every time I looked at it in the shed 20220220_080419.thumb.jpg.a998a718430dad39166e5260ad1e99df.jpg
In other news: lowering the engine to fit the spacers looks like a combination of lowering the engine mounts by 5mm and the K-frame by 5mm, this will give me all the clearances required and not screw with rhe steering geometry
Well, that's the plan
  • Like 4
Stuck the suspension in
4wd gasser mode go on
Guard to center of hub
Front 365
Rear 355
Clears all the speed humps around work, no scrapping on the driveway at the girls
Dampening set to 10 clicks from full hard, may soften it up a bit more though
Car needs s wash bad
  • Like 1
On 23/02/2022 at 3:37 PM, GTSBoy said:
I don't like it. Lower it 75mm and change the wheels to something extremely chrome.
On 23/02/2022 at 3:54 PM, Ben C34 said:
SSSSSSSSSL Springs bro
Nope
Need height for gutter jumping
The old girl is just about to hit 140k km, so near on 25k km since I got it in April 2020
And whilst the initial plan was to only keep it till I found something better, it has grown on me, to the point of I cannot see myself selling it
Even Jackie has come around and enjoys going on long country drives, although she does sleep through alot of the driving, it's just like cruising on a comfy lounge chair
I am truly owning the bogan V8 cruise ship lifestyle
  • Like 1
I genuinely enjoy cruising around in an auto 2008 Hyundai Accent when I just want to go places and don't want any fuss, performance or emotion and just look out the window all tranquil like when I commute about, so I understand the above post and where you're coming from.
  • Like 1
  • 3 weeks later...
New boots for the Bogan machine
Rear are 275/40 17 Toyo Proxes R888R, 100 AA A UTQG, some OK reviews from people using them as daily and drag tyres, supposed to be much better the MT S/S Drag radials in the wet, nearly as good as them in the dry, and better that my current RS4 in the dry, supposedly , time will tell, if they are good but wear out real fast, I might get a second set of 9.5 x 17 FR-1 for fair weather driving. $300 a tyre
Fronts are 235/45 17 Toyo Proxes C1S (oem size), which will surfice as the car is a big fat boat where hitting corners hard is not a thing, they just need to not aqua plane me off the road when its raining, well that's the plan anyway, $155 a tyre
On 13/03/2022 at 10:33 AM, Duncan said:
Have you done many klm with the rears on? I'd expect them to be mega noisey, that's the price of grip....
Yeah, they might sound a bit like muddies on a 4wd, but they should hook up alot better.
The ain't fitted yet, Jackie picked them up and they are sitting in the garage.
I'm currently in Lismore pointing at things that are muddy and/or broken for the "team" to pick up, or, working out how to get cows out of the top of trees.
It ain't pretty here.
Tempe tyres told Jackie they are only for race cars, after she picked them up she called and asked WTF, LOL, she was having a moment, I'll buy her something shiny and all will be well again on my return.
Comprise is another one of my middle names.
I had to cancel my booking at Autotech to get the thermal spacers installed because of work, meh, work pays the bills, but whilst I've been away I've had a little down time here and there, so, .........Idle hands are the devils play thing.
I've bit the proverbial bullet and will get the interchiller done at the same time.
There isn't alot of options brand wise, but Autotech has installed a few FI-interchillers with some really good results.
I'm not looking for more power, it's just to keep the IAT under control, and by under control I mean possibly below ambient IAT, dependant on how deep I want to go with additional condensers, other "stuff" and coin
https://fiinterchillers.com/
  • Like 2
That is awesome, provided you have a water to air cooler already...
Now I want it... even though it is entirely unusable for me.... how do I run a water to air cooler and an interchiller while being N/A lol, I demand sub zero temperatures!
  • Haha 1
I'm just waiting for a Spiro to give me call, I'll drop some coin so he can gather the required parts, then when everything arrives I'll drop the car off for some......images.jpeg-1.thumb.jpg.c4da7e7c613dabb46801259108f4de85.jpg
And by "when everything arrives" doesn't count for other random bits that may be required mid install.......as usual 🙄
Bloody cars
Just keep in mind this kit insults the laws of thermo dynamics. It WILL solve your issues by running the kit before you launch the car and having IAT _before_ you drive.
However if you're driving all the time with the system on, your AC must also always be on. You will lose more power driving the AC compressor than you will get from colder IAT's. Damn you, fundamental laws of the universe.
(it however could reduce knock etc, be more consistent though).
My beastie isn't a race car, my aircon is always on anyway, so cruising around will always have low IAT as the chiller is, ummm, chilling.
The issues come when the car is at full throttle, the AC shuts off and then once the chilled coolant has gone thru the wta intercooler it starts to warm up
But, it will last a no problem for a roll.
Ive chatted to a few people with them and they have nothing but good reviews.
They recommend getting a larger header/coolant tank for the WTA cooler if you want to keep sub freezing coolant for a whole 1/4 mile pull though, although only a coulpe of cars actually had the larger tanks, and the cars that didn't said that the AIT only raised a bit at the end of a run, and it only took a couple of minutes heading back down the return track to get the coolant temps down super low again
I'm not to fussed though, as long as my IAT is happy enough to not pull timing.
It looks like weird science, and I'm all for weird science
kelly-lebrock-weird-science_u-L-PJ796S0.thumb.jpg.1988b9976513386624f2dd587a5d4544.jpg
  • Like 1
It might seem like it does, but it actually doesn't - by a long way.
The beauty of compressor based phase change cooling/heating is that you leverage the mechanical/electrical power you put in, by a factor of (up to) about 5. Exact same as reverse cycle airconditioning for the house. When used as a heater, you put your 2kW worth of electrical power into it, and you get about 10kW worth of heating out of it. All courtesy of the remarkable ability of heat to want to flow downhill all the time.
Can I have this in laymans terms? Or.. more layman?
Would this actually work as a net positive?
Assuming the scenario where you're belting the car around a racetrack for 30 minute sessions, with the AC compressor on the entire time... assuming as well that it is geared to not overdrive itself at a hypothetical 7000rpm.
Would there be a power gain by having a 1C IAT instead of say 25C, and would it offset the parasitic loss from driving the AC compressor?
    • Appreciate the feedback. It is street car, but not a daily. Last week I got a quote from a good exhaust shop for a decat, one which is bolt-on, bolt-off to be easily replaceable. I got quoted for around €150. I usually do push the motor, but I wasn't in this case to make sure that no damage is done until I get the cat sorted. I think it's best to also ask the exhaust shop for the other option and see what they can do. If (big if) I were to decat though, would it be best to tune the car or would the stock ECU handle it? As far as I know, the stock ECU is not tunable and that would require additional purchases.
    • As above, definitely bash it or get it replaced with a high flow unit.
    • get some flares on them, or wider guards haha
    • Another question sorry, what stainless do u use in the turbo external WG plumb back piping? Is it 321, 316 or 304?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
