It was the little red oil light, that occasionally comes on when it is idling, that talked me into looking into it
Meh, playing cars is fun, spending money is fun
Engine might get refreshed next year.....🤔
  • Sad 1
Needs more twin turbos, also will act as mufflers.
Car will make good noises, less push rod LS noises and whoosy noises. Public (me included) will like more quiet and whoohy Commodore.
I've had a few turbo cars over the years, all made mandatory choo choo noises, but never a supercharged car, now I do
Frankly, the power delivery of this kills every turbo car I have ever owned, it makes about the same Hp as my old 25/30 in the boat, but, pisses all over it from idle
Power wise it delivers better than anything I have ever owned
I actually prefer the V8 throaty roar and blower whine over the choo choo noises from any of my turbo cars
As for the public, all I get is thumbs up and comments about how good it sounds
If we ever meet up feel free to have a drive and give it a little boot, that way you can make up your own mind, I'm as biased as 10 biased things
  • Like 1
On 12/08/2022 at 4:32 PM, Kinkstaah said:
These are really great concise videos tbh!
(I also have a melling pump)
Which one do you use?
Your bottom end is still standard isn't it?
My bottom end was rebuilt... so I think it's standard? Or refreshed.. standard? I didn't do it - I bought it with a lot of receipts but it has new bearings, new pump and was re-assembled. Apparently I have the standard flow, standard pressure pump. I did notice the oil pressure for a LS at idle is quite low, but not critically bad, I am happy that it's at about 28psi now (that my gauges work/don't leak).
I would have probably specced the high pressure one, but I'll admit my ignorance after making my other post, I don't see how the pressure spring changes things. Given the pressure is a resistance to flow... high flow should also = high pressure, and your oil pump specifications should be dictated by how the engine is built (hence the sincere thankyou video man)
The springs just lets the valve bleed off pressure/oil and it bypasses the feed gallery and heads back to where the pickup feed is
On the LS the oil gets the the bearings...eventually
This vid explains the OEM pump well IRT the pressure release valve and how the bypass works
The oil pressure light coming on intamitantly could just be a sticky valve, but, why pull something apart and not put something better in
I believe the low oil pressure light comes on somewhere between 5-10 psi
Well will stick a gauge in after the installation to see what difference it makes at hot idle and higher RPM, and by high RPM I mean 6300 RPM.....LOL
Haha likewise, take my shit box for a spin and maybe you'll end up wanting a R33 shit box again lol...
On 17/08/2022 at 2:41 PM, GTSBoy said:
Nek minit - LS pulled out, RB2530 transplant.
Nope, been there, done that, never again 🤯
The old girl is only at 145,000km, the engine is basically only just run in 👍
  • Like 1
On 19/08/2022 at 10:52 AM, robbo_rb180 said:
Almost a full resto, good yout getting little bits done so its more reliable.
When is the next trip out to the drags?
Not sure, I'm in no real hurry, "proof of concept" was the 122 MPH trap speed
In the end it's just a fun street cruiser not a racecar
Found out that the occasional "squealing" from the serpentine belt when I backed off after a big hit wasn't the belt slipping, it was the OEM harmonic balancer trying to spin itself off
LS1's don't have a keyway to pin the balancer to the crank, it isn't needed NA
BUT, "apparently" your meant to pin them when you build a engine and fit a supercharger, to stop this from happening
My fancy new balancer and crank has now been pinned so they play nice together
Hooray for preventative maintenance
  • Like 2
On 24/08/2022 at 9:45 AM, Duncan said:
ouch. harrop probably should have mentioned if that is a thing...
AI had a look at the Harrop site
Apparently it is an optional extra for "added security"
Meh, it's sorted now
Got bored at work, went for a cruise for a few hours around Sydney, car is a dream to drive, literally flys under the radar, did get stuck in peak hour though for a while, big comfy seats and the slush box makes it a pleasure to drive, pumped some old PIL (Public Image Limited) on the head unit and just enjoyed life, ended up eventually getting some free air when a noisy, fart tuned C63 AMG something something sedan pulled up and tried it on, at "WSID" LOL, nope, Bogans 1, Euros 0
The Bogan cruise ship is so unassuming
My problem now is when I picked up the car, Spiro from Autotech he got out his Moroso calculator, done some sliding around with it and said some Mickey T drag radials should get me a easy high 10 at around 128mph
I would need to drop my current 2.4 60' to around a 1.6 though
So, can I justify getting some 275/40 17 drag radials when the R888R's are worn out??????? Can I ????? Really ????? Can I ??????
YOLO
I'm now looking at another set of of Gold 17 x 9.5 FR1's for street duties with some 255/40 17 Toyo Proxes T1 sports, mainly for daily duties and long weekend trips away up and down the coast, and sticking some 275/40 17 Mickey Thompson ET Street S/S on my current set for "fun" in the sun
Yeah yeah, I know......
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
