1 hour ago, Kinkstaah said:
Why didn't you buy the one I originally linked in QLD which was about 18k and in massively better condition with about 30k of tastefulmods holyshitmygodjesuschristman.
I've driven that one and it's a great deal and drives nice. The owner definitely treats it right on track. You would have gotten it for what you paid for this one too.
Keen to see what you do to this one.
  • Like 2
The one I got has 50k km less on it, and is in good nick, plus was relatively local, I wasn't going to fly into QLD to look at a old MX5
As for the mods, meh, I just want a comfy fun little car for the street
In other news, we took it to Goulburn today to lunch with the daughter, good times
Mrs did insist on me putting the roof up about half way there as she said it was to cold, I did tell her to rug up before we left, but, nope, fashionable attire won, bloody convertible rookie
  • Like 1
2 hours ago, Duncan said:
This thread always delivers, thanks again mate
Talking about deliveries
I have one on the way from MX5 Mania already, only for a little added noise really
Plus I'm waiting on Super Cheap for every oil, fluid, filter that goes in it, and some new plugs for it as well, because why not
After that is all finished it's off to MX5 Mania for the ECUTEK, mainly because I want the rev match for when I'm racing to work or the local Coles shopping centre 🤪
Axle back, new thermostat and coolant bottle arrived from MX5 Mania, I'm still waiting for Super Cheap to get back to me with my order, once I get everything in my hands I'll take some leave and "play", starting with serving and fitting parts, then detail
I honestly think this is the most fun part about getting a new old car
1 minute ago, MBS206 said:
In roughly 6 to 9 months time, what mods will you have done, and how much can I buy the car for? :P
I thought you might have asked about the Honda, but as the boy just wrote off his Patrol, and was trying to find a cheap daily to get by with, I decided to give the Honda to him
Ha ha ha, I read that he had it based on brownie points so knew it wasn't going to be sold :P
I also am only shit stirring on buying, while they'd all be great cars, I don't need more, I actually sold one a few weeks ago. And immediately bought more tools... :P
  • Like 1
Talking about tools, my trombone cleaner arrived, talk about weird speciality tools....
Bored at work, so...
Out with the old
In with the new
Sounds good, and most importantly, no drone
Thinking about being bored at work again tomorrow, or maybe give myself a EKO so I can do the new thermostat and coolant reservoir
4 hours ago, Dose Pipe Sutututu said:
Mark needs to get bored at work and order things on here...
Whilst putting a V8 in a MX5 would be fun, it would negate the whole cheap to run fun daily that the MX5 will be used for
If I wanted a faster little convertible I would have got a engine check light, I mean a BMW Z4 M, but going off the issues that the guy at work who recently got one is having, it is lucky I didn't
Meh, horses for courses, the Bogan Cruise Ship is my go to for some horse torques
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
    • The axels in my R33 seem tired, and have a bit of play in them. I cannot find any new of course, not interested in buying used, but I am looking to see if anyone can identify some cross compatible axles. In the states I have seen suggested for S chassis the J30 axles, however for the skyline (as best I can tell) the lengths are about an inch off (2.5cm) on both sides. R33 my measure L 22" R 24.5" GPT L 22.5" 24.25" J30 L 23.5" 25.5"  so shaft length is probably an inch wider. Not sure if someone has another still remanufactured option besides the J30. I figured worst case I can buy a pair tear them down and swap the center shaft. My other option was reaching out to GSP to see if they cannot piece together a set, since the axle stubs are still manufactured, I wouldn't think it be that hard to find a shaft or make a shaft work.
