12 hours ago, Ben C34 said:
It reminds me of something but can’t quite put my finger on it
how does it “ wrap” around? Is it a fitted thing or like a blanket ?
Like a blanket, it has some "clips" sewn onto the corners, you just need some stainless zip ties to secure it, not sure if the "kit" comes with the zip ties or some form of strap
I'll post up some picks when it arrives
  • Like 2
Please do, I've been examining this thing, and the only picture is for a V8 that is *not* the LS1 manifold. (it's from earlier Chev V8s')
I am wondering how this thing would go with the coil pack leads.
It doesn't look like it'd fit over (over the coilpacks?? across the top of the plug leads?) and has no provisions for spark plug leads themselves.
Please post an update as I have the same item sitting in my cart at EMA 😛
I'm kinda hoping that it l9ng enough across the top to push some down under the plugs and leads
Well that is what it looks like in my head, I'm hoping to not "cut to fit", but that is always an option
Just like putting it in the bin after getting the shits with it is always an option
I am quietly confident that is won't come to the "bin option" though
I did try to fab up some of that aluminium sheet stuff(pictured), but that did go in the bin, with the headers installed it was a right PITA to form it up, and the best I could do with the headers fitted looked like a dogs breakfasr, but, if the headers were off, the aluminium sheet stuff would be my No.1 choice, even over wrap
Also:
Why are you doing it?
Does your LS:
1) Overheat if you turn the AC on, on a hot day? (stay away from a UDP if it doesn't)
2) Saturate your engine bay with so much heat that putting the fans on "fresh air" results in like 50+C air being thumped into the cabin?
3) Anything else?
41 minutes ago, Kinkstaah said:
Also:
Does your LS:
3) Anything else?
Nope, purely from boredom and best practice
OEM has a heat sheild, this doesn't, I've typically had some form of thermal protection on any and all modified exhaust manifolds to quell radiant heat
My next mod, for no other reason than I think it is best practice, will be to create some form of ducting from my front bar to the radiator, currently air can just drop down under the radiator.
As I've added a trans cooler to the stack I feel it would be a worthwhile project
From recent experience, the very best stuff for this is signboard. It's the stuff they use for real estate signs and the like. Thin sheetmetal each side of a thin plastic core. ~3mm thick. You can score it to bend it. You can roll it around a mandrel to make a radiused bend. With a couple of little bends put into it it becomes massively stiff, because it's already pretty stiff, being a composite construction.
Duck's nuts for undertray/ducting work like that.
This stuff?
https://www.ebay.com.au/itm/Aluminium-Composite-Panel-WHITE-BLACK-600-x-400-mm-Building-Signage-Trailer/172785939441?hash=item283ad833f1:g:41MAAOSwblZZJjTD
 Fixing non existant issues is  a nifty plan, but  how about forcing air into the engine with the help of a spooly Boi or spinning rotors?
The car is currently extremely reliable, if I want to fix that issue, I could boost it
I did look at giving it a bit more "poke", but the additional torque would require a built gearbox, amongst other things, and questionable reliability, so, I though that the amount of money spent on boosting a old commodore could be spent elsewhere
On what, I haven't worked out yet
  • Like 1
46 minutes ago, Duncan said:
Patience! He said the same about the 86 for the first 17 pages...
Honestly mate, I would rather get one of these to play with> https://www.carsales.com.au/cars/mazda/mx-5/se-badge/nb-series-4-series/manual-transmission
My google search keeps gravitating back to MX5's
And it would cost much less than boosting the old Dunnydoore
My gf is literally about to put hers up for sale. Feel free to ask away if you like (about it, or them in general) via PM to not clog up thread.
Unless you want to clog up this thread after all, as it's your thread, do what you like man, fk the rest, turn it into a MX5 thread so this little thing lives on.
Send linky please
Fitting heat sheilding- part 1
Ok, so the stuff arrived
As usual the ebay description was not quite correct, there are no tabs on the material at all.
So, I just stabbed stainless steel cable ties through which has worked a treat.
As for the sheet size and fixing it to the headers.
The "kit" consisted of 2 sheets of about 25" x 20"
Issue: using 1 full sheet wasn't really going to work for each header due to the limited access in the engine bay
Fix: I measured up both sides and worked out where I had access, turned out cutting the sheet in half 25" x 10" worked a treat
When fitting I pulled the coils for more access but left the leads connected to the plugs to form the stuff around
lots of ties later
20201221_120119.thumb.jpg.87130f16b61c5f4b94db8116030173bd.jpg20201221_124234.thumb.jpg.01938cf159c36565634d93a72f05a97a.jpg20201221_124715.thumb.jpg.3b86b4e3a474ab5167b1632b717bb093.jpg
Since the pics it has been cured (yeah, pretty smokey) and has seemed to form fit a little better.
For coverage as of now is from the primaries just past the first collectors
Part 2: next time the car is on stands, sometime this week probably, will involve using the remaining sheet, cut in half, and placed over the top of the secondaries to keep the heat from them radiating into the firewall and foot well, well, for 25" anyways
In the end the difference in radiant heat is very noticeable to my uncalibrated hand, yeap, I though fark it and proceeded to touch the headers after the drive to cure the stuff, yes it was hot, but, no burns or melted skin, which was nice
In other news: I noticed your sound deadening, nice, I got some of that "car builder" thick underbonnet soft foam stuff and cut to suit the frame, I am just waiting on a new OEM style underbonnet sound proofing to turn up to neaten it up and add a little more sound proofing
Groovy
  • Like 3
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
