I support this from the firewall forward.
Actually I lie, there's a guy with a still streetable SS doing pretty respectable times at Winton, so as much as people on SAU bitch about Commos' being unable to handle, it clearly can be done to a pretty decent extent. Realise this is an auto so you won't be doing that... but still.
https://www.carsales.com.au/cars/details/holden-commodore-2005/sse-ad-6431803/
Smaller cams are better choices if you want the thing to be good at what it does best (i.e be a comfy cruiser around town), cam surge will ruin everything.
  • Thanks 1
Just did oil and filter change.
Pulled dipstick and noticed it was a little cracked, so....I wobbled it and it broke.
Dip stick is now about 1.5 inches to short.
Fill with filter is 5 litres, so I just dumped the whole 5 litres of Castrol Edge 0w 40 into its belly.
New dipstick is incoming, thanks to Ebay.
41 minutes ago, mlr said:
Bring on the broken stuff...
I have the full Holden service info pdf set, it is massive. When iam able to operate a computer correctly I will pm a Dropbox link to you. Few beers in so could get bad athe moment
  • Thanks 1
Just ordered new Ultima struts and FE2 height king springs $600 delivered (I pulled a wheel and the shocks looked like the originals from 2002, the FE2 springs will give me an additional 10-15mm height, helpful when doing Dukes of Hazards jumps), and some $20 spring compressors (again, I cannot find my old set, meh, $20, ppfftt) off Ebay to swap out the strut tops.
But tomorrow is coolant flush then full external clean, wash under the car as well as the paint, then polish, glaze then wax.
I'll also give some of the fixtures a squirt with penetrant in preparation for undoing suspension nuts and bolts, hopefully next weekend.
Psycotherapy and a bit of a work out.
… could I also get this? The VZ one is a fkin DVD and near impossible to find. I have the VY Series 1 one, but they... change stuff.
Mark if you want to be a real bogan now that you have a Commo you will have to install the mandatory bow tie badges.
My daughter who is not a car enthusiast always says "bow tie badges on a Commo would make baby Jesus cry" whenever she sees a Commo with them.
Go on you know that you want to.
LOL, Chevy badges on Holdens causes the AIDS.
In other news
Coolant flushed
Car is all clean and shiny
Decided to do the spark plugs.....but.....the first lead I pulled fell to bits
$130 later I now have
For
Jobs for tomorrow
Plugs and...leads
Trouble shoot inactive cruise control. i.e. "look at the fuse"
Pull door trim and see why the front inside passenger door handle doesn't work, well I know why it doesn't work, the handle is good but it seems to be missing a spring or something????, I'll most likely pull the trim off the drivers front as well to see what it is meant to look like.
Plugs and leads are done.
Also replaced the OEM heat shielding (masonite with tinfoil glued on) with real heat sheilding, held in position by 2 x OEM clips and 1 x cable tie (LOL, cable ties already)
Door was a cheap fix, just needed to reconnect the clip.
Getting to the clip on the other hand was a PITA, lots of jamming the phone inside and taking pics, then jamming my hand in and blindly fumbling around until the blue clip was reattached to the rod.
I want more sidewall.
I going "full bogan spec"
17 x 9 chasers with black caps.
I'll get some Hankook RS-4 255/40 17, should give me 20mm more sidewall.
Slight diameter change, 24.8 diameter, as opposed to the OEM 235/45 17 which are 25.1.
Should be 100kph on speedo and 99 on, ummm, the radar gun.
Will sell the 19" Simmons once the car is "full bogan spec".
  • Like 1
  • Haha 1
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
