1 hour ago, Dose Pipe Sutututu said:
Mum's memorial burnout for dead sons | Queensland Times
LOL, yeah nah
I also don't know or associate with people who dress in their Grannies sleeveless cardigan or her weird ill fitting slacks
I am happy to put a bag of delicious cinnamon donuts on the line at WSID on Wednesday night, that is if the Skylines are currently running............🤣.......LOL
JK.......but seri😜sly
It's back to being an expensive shelving unit, recently got an emap damper and pressure sensor. More parts for the parts museum.
  • Like 1
Damn it
I now have a gearbox full of neutrals
Goes in Tuesday for diagnosis/fix
Damn it, I'm heading down to Goulburn to lunch with my daughter on Monday, looks like in riding the bike, and freezing my balls off
LOL
  • Sad 1
16 minutes ago, robbo_rb180 said:
damn, was it a good skid??
So upgrade to a turbo 400 w/transbrake 😁
Not even a skid, just cruising on the M5 and put my foot down a bit to change lanes
No bangs, no clunks, just no drive
I'm hoping its just the solenoid
Fingers crossed
Meh
On 05/06/2021 at 9:55 PM, robbo_rb180 said:
Hopefully an easy fix at least you have the bike to enjoy while it's getting sorted
Bright side was the bike ride, if the car was working I would have pussied out and taken the car
And with about 4 layers of clothing I wasn't cold at all....🥶
  • Like 1
All is well in Bogan land
It turned out the transmission pump rotor went bye bye
So after a full strip rebuild, and some, read: alot, of flushing, which was covered by warranty, it is good to go and the old slush box lives to fight another day
There was a few reasons why it may have failed, but nothing definite, apparently it is rare for them to fail, but it did, meh, but now it has a nice new one in it
Apparently it looked like this pic, not mine, but you get the gist
38 minutes ago, Kinkstaah said:
Excuse me your gearbox/transmission issue is supposed to take 6 months (and counting) like mine.
Mark follows the silicone valley "Fail Hard, Fail Fast" mantra
  • Like 1
27 minutes ago, admS15 said:
The reason it failed was a protest to you about not doing enough skids..
This!
If you did a phat Troy Candy kind of skid and ended up on the news your box would live another day.
Commos, snorkels, bogans, burnouts
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
