20 minutes ago, Dose Pipe Sutututu said:
AIM MXS dash?
Also can do logging
My curiosity to coin ratio only extends so far
$1500 to see my trans temp and AIT, yeah nah
Plus that AIM dash would look so out of place in the old bogan cruise ship
  • Haha 1
I have a head unit and can thus run any ODB2 app I want. I have the entire torque pro app running in the double din with all the gauges I need.
Note: Don't need any, as I have enough mechanical gauges. But I can put extra stuff there!! And stupid shit like 0-100 runs, or my track day telemetry.
Also Trackaddict is great. And allows overlay for all the circuit things, and does not interfere with god knows what. Go one step further and just tune your f**kin car and buy a MPVI2 lol.
The tech has progressed past whatever that thing is now, and if you want to say have gauges for everything, that is what ODB2 and some kind of display/screen is FOR.
😭 I just want to know my trans temp and IAT 😭
As for tuning, I can barely log on to the interwebs, let alone play with that black magic tuning thing
I can see it now.
"I am going to try tuning my car"........NEK MINNIT.......
  • Haha 2
I can see it now.
Trans temp and cooler are actually pretty important. I remember my hi-stall adventures, its well worth knowing so you can freak out as it climbs in traffic like I did before I installed a fan for it!
  • Like 1
Bugger
The trans doesn't in fact have a trans temp sensor, no trans temp for me thru the OBD2....spoke to Craigs about this and they believe my temps would be fine anyway as the trans has a big pan and a big air to oil cooler, I asked about if cold fluid temps would cause an issue and they said as long as the engine is at temp the trans will be fine.
Meh, the scanner showed no codes though, which was nice
I'm still happy with what it actually can do
Currently it got volts, coolant temp, IAT and boost
I wish I had this when 1. My alternator died, or 2. When my battery died 6 months later..
IAT goes from about 50°c cruising to 80°c during a long hard pull down the local strip at work, hot yes, but hot IAT is a thing with a PD supercharger, you cannot really tell the difference in performance and the ECU black magic deals with it anyway, #notaracecar, soooooo, if my IAT vary from this I may have a coolant flow issue to the W2A intercooler
This tells me that a PD supercharger is great for the street and strip, where a 5 to 10 second hit is all that is needed, but it would be rubbish for the track where you are constantly on the loud pedal, I would assume heat soak would be rampant after 1/2 lap at your local motorsport park, and possibly the ssme for towing...maybe.....
Coolant temps are a fairly fixed 93° c once up to temp
And boost is boost, unlike a turbo which can overboost, the PD blower either blows, or it doesn't, and of it ain't blowing it's because it's dropped a belt
Put a real temp sensor in the line that runs from your trans cooler - That's what I did.
80C while your foot is down? That is ridiculous and has obliterated any desire to ever get on boost.
50C is already massively heat soaked. 80C after a few seconds makes me wonder if your intercooler even exists.
Dang.
  • Like 1
Dang.
But strangely those temps seem to be a thing when it comes to PD blowers, I initially freaked out but the tuner said it is typical, then rang Harrop who said it's typical, then Googled it....google said it's typical and/or that the sensor might heat soak because of it's location, meh, the car is perfect for what I want so
And I knew going in that a PD isn't as efficient as turbos IRT IAT, but I'm happy to compromise a bit, the car goes like a cut snake from idle
Craigs suggested if I really want trans temp to get a bung tapped into the pan for the most accurate temp, I might get this done next trans service
I will chase up some logs from a mates car for reference, it is very similar. I recall it will heat soak high but then giving a squirt will go lower due to airflow .
Lsa engines go up like crazy when giving it a blast. Easily add at least 20 degrees over a quarter mile pass. Those intercollegiate in the blower are laughably small.
Don't look at interchillers. Don't think  about having a system that gives you air inlet temps below zero.
What's wrong with interchillers?
On 09/07/2021 at 11:07 AM, Ben C34 said:
Nothing. It's just something else you will look at and buy but don't really need!
Nothing to see here........
Quietly googles interchillers........again...........yeah, nah, the car is boss for what I use it for and it seriously doesn't need any more power
For the occasional street pull I cannot see there being any real reason
As for unnecessary modifications, well, there is always an electric power steering pump from an Astra, and/or electric water pump, both are not necessary, but for some strange reason I keep googling them........
It's like/is a disease......LOL
  • Like 1
As I was bored at work, and possibly somewhere on the spectrum
I had some of the stuff I used to cover the headers left over.
It's pretty toasty inside the engine bay, hopefully this "may" help with the radiant heat on the cooland lines and reservoir
And running my WTA lines inline with my 90° coolant lines wouldn't have been helping either
Will it be noticable? I'll see gow it goes next outing. Either way it got me away from actually doing real work
EKO TFIF
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
