On 13/05/2022 at 8:22 PM, Dose Pipe Sutututu said:
Wot, damn...
Money they couldn't resist I suppose.
One possible benefit is due to opening up to the huge US market prices might settle a bit
Currently the 2500T goes for around $4500, then add in pinning it in, and tuning, and the other "supporting" stuff that it needs,  it will be a costly endeavour
You seem to be all over "tuning and stuff", do you have any experience with torque management????
Fom my research the Haltech  torque management is awesome, and there's no point in having alot of powers if you cannot lay it down
In theory I know how to set it up, and know how to adapt different strategies to manage torque such as reduce timing on wheel slip (and ramp the time retard as wheel slip % increases), and/or apply the same on the DBW throttle body as wheel slip increases you decrease the max amount the throttle can open. For boost applications you can even trim duty cycle etc. Then all of that you can even throw on-top random cylinder cuts to reduce large amounts of torque.
I'm planning to install either a front wheel speed sensor OR (lazy way out) a GPS sensor and calculate slip % then apply whatever strategy above works most effectively and efficiently. Just avoiding the full cut traction strategy of boring A to B OEMs.
www.racetcs.com
By far the simplest way for what you want (which is wheelspin due to power)
  • Like 1
On 14/05/2022 at 8:08 AM, r32-25t said:
Haltech themselves also say it’s not true
Cool, my info must be off, the guy I was talking to was pretty confident and says he is tight with the owner
On 13/05/2022 at 11:01 PM, Kinkstaah said:
www.racetcs.com
Looks like the old race logics one
Pretty cheap, which sort of worries me
I wonder who can wire this puppy up for me?
  • Like 1
It is basically the racelogic one that I have, and works really well with minimal f**king around, it doesnt take a lot to get it to function better than you expect.
Anyone can wire it in. As long as you can identify your injector wires, and your ABS/wheel speed wires from the factory car, you can splice this in. It'll work with the factory ECU as well, and by work with I mean entirely independent of, which doesn't cause a problem with the factory ECU, basically.
  • Like 1
On 13/05/2022 at 11:26 PM, r32-25t said:
I can’t find any information about Holley buying haltech
I just heard about it over on performance forums. The guy who brought it up is a haltech distributor. He said it's been sold to US company race winning brands.
Regarding halaltech
Holley did make an offer to buy but haltechs owner knew it would have been the end of haltech and didn't accept their offer. So there was truth in what you heard @mlr
https://www.businesswire.com/news/home/20220511006064/en/MiddleGround-Capital-Completes-Third-Add-on-Acquisition-of-Haltech-for-Its-Race-Winning-Brands-Platform
I never did a video on how well mine worked/didn't work as there's enough out there from the various manufacturers.
I can let loose in 1st at 5000+rpm in the wet and the the car just drives straight. It does wiggle a bit relative to how much slip I dial in on the dial.
You would know that letting off otherwise at about 2000rpm results in a hilarious burnout on road tyres, even if you never posted a video of said rubber destructive test.
Caveat to above audacious claim: Mine is configured to kick in at 4kmh, (the nissan sensors don't pick up a reliable speed lower than that on all 4 wheels) so I have to get the car to 4kmh before truly just going flat foot on the accelerator/fully dropping the clutch.
I even only have a 6cyl system, so it can only ever cut 6cyl. I still can barely notice it activate as the car cuts in/out 2-6 of the 8 cyl. Also from testing/setting up, I can tell you a LS does not move under its own power with 2cyl active only, so you don't really need an 8cyl version.
It works great in corners. Pin 1st at 5kmh doing a u-turn and having the car not lose traction is VERY DIFFERENT to what happens with the system off.
  • Like 1
Stupid US dollar
My impulsiveness kicked me in the balls with the current exchange rate, and shipping was exxy for what it was at $107US
Meh, as the cool kids say "Yolo, sent it, hold my beer" or something like that
  • Haha 1
Sounds like it's doing the job it's designed to do well.
Can you turn it off if you're in Mexico and want to rip a skid?
Sadly my car is non abs. I wonder if it's as simple as retrofitting some speed sensors or if it needs signals from an abs module?
Yes, you can turn it off and rip skids....in Mehiko
Or for heating up tyres at the drags
Have a google, apparently you can fit sensors to anything really, cost to fit said sensors is ????????
There's a dial that has the amount of slip you want (0%, 5%, 10%, 15%, 20% and off in my case)
So at the turn of a dial near my left knee you can indeed go berzerk.
It just needs access to a speed sensor or something that pulses in time with the wheels and it uses that for it's calculations. Racelogic used to sell a wheel speed sensor kit and a wheel speed sensor version but it was a bit more pricey. I don't think RaceTCS has that but given they label their own item as "Racelogic alternative" I wouldn't be surprised if it shows up soon lol.
  • Like 1
Can you shoot me some info about how you wired it into the injectors and abs
My plan is some stranded CAT6 twisted and sheilded for the ABS
How did you/what did you use, to connect into the ABS/injector wiring? Crimps/solder??? Chewing gum???
For the injectors
Option 1: I'm either going to get 9 different coloured 0.75mm stranded wire for the 8 injectors and 1 earths, then make up a harness with corrugated conduit and heat shrink
Option 2: Get 4 x 5 core 0.75 FVV, 2 x 5 core each bank for my injectors in and out (allows me to keep the same colour wire for the cylinder in and out, and the spare for the earth
Any pics or recommendations would be most welcome
I'm looking at option 1, but I may be missing something simple
Now, where or my wiring tools that I last used 22 years ago?????
Who am I kidding, Jaycar here I come
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
