On 08/08/2022 at 12:03 PM, Dose Pipe Sutututu said:
WTF, how did that even happen
Meh, more parts at the wreckers or gumtree for me to browse through
And the more that get written of the more mine goes up in price, and for a Commodore, that is weird, but true
  • Haha 2
I sold my VT2 SS LS1 6spd with usual mods (headers, exhaust, intake, tune) around 8 years ago. Was on the market for 6.5k for around a year before it finally sold for $5600. Struggled to even get anyone to come look at it.  I see guys asking 15-20k for them now and most of them look clapped out compared to mine.
Ah, the times we're living in.
  • Like 2
The Cruise Ship is in dry dock (Autotech)
It has developed a knock in the steering, mainly on right handers, I had a look, got the shits rolling around on my back under the car without finding what is was, so sent it to Autotech so they can put it up in the air and have a good look around, I'm guessing its a rack bush
While it is there I've asked them to do the front main seal, which currently losses oil at the rate of about 1 drop per week, which is annoying.....so.......seeing though the harmonic balancer needs to be pulled.....I've asked them to fit a Melling 10296  high volume pump, because.......why not
  • Like 1
On 11/08/2022 at 9:44 PM, The Bogan said:
Nope, I has blower, so I don't need no stinking turbos
well.....
you can haz both? supercharger with twin turbos.. will make all the right noises :D
On 11/08/2022 at 10:09 PM, Dose Pipe Sutututu said:
We should roll race one evening for laughs at Roll Racing. We'll be the 2x slowest cars there too.
I'm always in for some fun
Do not get the high volume pump - You will be just pumping oil harder into the heads and through your PCV system, and emptying your sump faster. What you want is the high PRESSURE pump.
So yeah that's why not
I mean is it a real issue given how you use the car, no
Did you need to change the oil pump at all given that information also no
I've been told that high volume pump will be advantages in it as opposed to high pressure
Higher volume with standard pressure for modified unopened engines
Higher pressure + higher volume for built engines, dependant on clearances
Melling recommends the 10296 pump (18% increase)with standard oil pressure for the unopened high milage and/or modified LS1 that lives under 6500 rpm
Melling 10295: Same volume as LS1, 10% increase in pressure over LS1 based M295 oil pump.
Melling 10296: 18% increase in volume, stock pressure over M295 and 10295 oil pump.
Moroso 22120: 18% increase in volume, stock pressure over M295 and 10295 oil pump.
Melling 10355: 33% increase in volume over the 10295.
Factory GM LSA: 33% increase in volume over the 10295.
Melling 10355HV: 53% increase in volume over the 10295.
I'm confused, isn't the flow rate at a given oil pressure determined by the engine rather than the pump fitted to it? I would guess that a high flow pump will just mean more oil pressure at idle but not necessarily more oil pressure otherwise. Assuming it was already hitting the oil pressure limit for the regulator.
A higher volume (bigger) pump will "keep" the pressure up in the low RPM's, I don't need more pressure, I just need what the stock spring gives me
LS1 engines typically have minimal pressure at idle and due to the design of the pump struggle to make and keep pressure, resulting in lower than desired oil pressure at low RPM, as I'm making full boost from the minute I hit the loud pedal more volume and a better design is required to keep the stock pressure actually there
The GM LSA has a pump that runs 43% more volume because of this, no more pressure, just more volume
The issue with the OEM pump is it also cavities at higher RPM due to its design, the Melling pump has better flow paths than OEM, which stops this happening, the higher volume also can help with the cooling and valvetrain noise at low RPM
The pressure required to meet the specs comes from the clearances, if I had a sloppy built forged engine the builder would specify what pressure was needed at the bearings, which, would then mean playing with higher pressure springs as well volume, I remember Yavus from Unigroup talking about this with my old R33 when he was playing with the regulator on the Tomei high volume oil pump getting it to the pressure the builder said it needed at the bearings. ..😟...triggered......R33.....triggered.....  😟.....oil everywhere........🤯
So, for my LS1 at least, by adding a higher volume pump, with better flow paths, the stock pressure will remain stable at idle to WOT
And for around $300, it is a cheap thing to do, seeing as though the balancer is off anyway to fix the front main
Well, thats what the voices in my head say
    • So, I've been a little busy on this car. I replaced the bonnet struts which is always satisfying but very confusing that nobody else on the planet seems to do this. Its just my routine first thing I do on any car I buy. The boot struts for both the tailgate and the separately opening glass window was a bastard. And, I found a fair bit of rust in the strut cavity. I filled it with rust converter and cleaned up as much of the dirt as I could. There was so much dirt. One piece of the trim was barely hanging on and so I've left it off. I'll try to get a replacement. You can see how disgusting and dirty it all was in this thread; I had to remove the little clips that hold the struts on the ball. The ones I took off had no clips and it was impossible to get them on with them in place. Fingers crossed they stay put. So, I turned my attention to the headlights, they were in a bad way and likely would stop rego. I took the headlights out and found the adjusters were all just loose. So, I fixed those and unclipped the lenses to clean them up. Couldn't believe how easy it was to take all this apart compared to the E90.   I also cleaned up the stockies which was awesome, these are super cool with lug nut covers. They're in good nic but the tyres are shot. I was going to use these for rego but in the end got a fresh pair of rubber for the 17's on the front of the car instead. The front bar of this car is from a late(r) model one. I don't think it's quite LCI but who knows. I'll need to find out. Anyway, the bar was missing the fog lights and the wiring and plugs were for the original ones so I got new plugs and some cheap fogs. I wasn't sure if missing original equipment would hamper my blue slip attempts. Had a couple of these little fellas helping out. But not Ben who got stuck behind the pool heater .... How embarressment.  I ordered new speed sensors for all corners because I knew one was out. I just got cheapies and will replace them with Bosch items when I can find Bosch items. Again, this was just for rego. Alas, it seems the blue speed sensors are not the same as the grey ones. Back they went and replacements ordered. In the end, with my new scan tool, it was just rear left that was shot. Replaced it and cleared the codes. All good now. Lastly, my aux (thermo) fan is being a bit odd. Its powering up at strange times and NOT powering up when I think it should (100C). While this can be caused by a few things, the most likely (for me) is the ambient temp sensor. Given mine reads -40.0C regardless of the temp, I figured it would be good to replace it. In the end, the sensor wiring was abysmal with (terrible) attempts made by somebody to fix it.   I fixed this all up but the sensor is only attached using pins into the wires. The plug is not there. Despite trying and trying to connect it securely it wouldn't work so a replacement sensor and plug is on the way. Oh, I also ordered a replacement piece of trim for the part missing here at the bottom. Ordered from Latvia for $70 delivered. I took a bit of a leap of faith because I didn't have the exact part number and, as usual, there were eleventy billion pieces of trim that looked to fit. Nailed it. Well, its not totally perfect but I think its more a 28 y/o car problem than a trim problem. And, as of today ..... I have bought the workshop manuals 2nd hand off a guy in tassie. 1000+ pages of E39 goodness, hopefully it helps me with the fan. I also have a new temp switch on the way incase its the problem. Stoked.
    • I don't even know that you want an M2 Competition as a track car. My rule for a track car is only risk as much as you're willing to completely total out. Clean stock C5 Z06 Corvettes out here are cheap. Buying someone else's already ruined track car is even cheaper. Maybe I'm just not that good a driver but even a Fiesta ST on the Nordschleife felt like as much car as I could realistically handle.
    • I've already gone over the cam. A new one is going in. An old one is coming out! The new one is smaller, with less overlap. It has way more lift, but it will be more mild mannered (hopefully, probably very minorly) I'm also measuring for two more mufflers, with the goal of having four mufflers in my car. But that probably will be done by an exhaust shop in a drive in, measure, buy parts, install parts later kind of deal.
    • Mine is not even a GTR and I've been resisting the urge to make it a power monster for the last 25 years. And as a consequence, I have driven it to work nearly every day across that span of time.
    • Since the motor is out, I suggest pop in a nice dirty LS chop cam. MOAR of this please:
