22 hours ago, The Bogan said:
Thinking of going even taller in the rear end
3.07, or even possibly 2.87
The 3.46 gears are much better than the 3.91 that were originally in it, and for all of the hwy cruising I do, and with the amount of torque the car has just off idle, and the stalled slush box to get the engine spinning I think the longer gears will give me more manners down low, and good fuel economy on the hwy
I have a 4.11 in mine, and a .63 6th instead of a .50.
Even with these (relatively insanely) short gears, my 1000kmh idle is like 1800rpm. With the .50 it was 1600ish? With the rear ratios you are talking about, I don't know honestly why you don't get a 4cyl econobox and play V8 rumble through the speakers.
  • Like 1
  • Haha 1
  • Confused 1
How do you find 3 & 4 gear with the 4.11? especially on race tracks.
Looking at LS conversion for new car and hard to get info on the nissan 3.9, 4.08/4.11, 4.3 ratio with the 6speed
17 hours ago, The Bogan said:
And after almost hitting a roo on my last adventure down the coast I want one of these smart bar plastic roo bar thingies
Currently got the feelers out and on the hunt
They have been known to do more damage to the car than roos......
Insurance will cover repairs if you do hit one.
  • Thanks 1
Because I like 500hp v8 rumble
I'm at 2300rpm at 110kph with the 4l60e and 3.46
Meh, in the end the car is a cruiser with some poke, it isn't a race car, it doesn't get locked in a garage all week/month, if I can have it fast, and somewhat economical on the hwy I call that a win
I got you fam
Source: me doing what you doin. This is with limiter of 6600 and 265/35/r18 tyres, and a 4.08 rear.
So, turns out it is 2123kmh at 1000kmh. The regular T56 6th gear is 1696kmh in 6th. Making before what I said a little fake news.
Also I forgot it's auto, yet again. I also just realised that the numbers I pasted right now are a mix of 4.08 but the rpm at 100kmh is the 4.11 rear. Cause I clearly am not sure which one I actually have in my car cause it makes no difference unless you're doing it all in excel 😐 😐 😐
I find the ratios to be near on perfect - That said I bought the magnum for the 5th gear being shorter which makes a mental difference but testing it IRL and in simulators like assetto corsa showed actually no difference in pace 😛
^--- also me
  • Haha 2
3 hours ago, Kinkstaah said:
I got you fam
^--- also me
Thats the info I needed, Legend.
I better start looking for a decent LS conversion kit.
Damn it
Got a "letter" in the mail
80 kph in 70 kph zone late last month
It was on an off ramp heading off the M5 near Casula
1 point and $128, not a big hit cash or points wise, but I've lost my gold licence, Mark has a sad
New headlights as the current 20 year old headlights have alot of really fine cracks that don't buff out of the plastic
Do I really need them, nah, because really you can only see them in a certain angle and a certain light, but at $200 for the pair delivered "why not"
  • Like 3
Heading into Goulburn to lunch with the daughter
Ambient temp was 18°c
Pre interchiller it would sit around 35-40°c at the same ambient temp
The R888R's on the rear are performing really really well and have been surprisingly good in the wet and standing/flowing water (small rivers running across the Hume Hwy)
Bogan life is good 👍
  • Like 3
Gave the car a wash, wax and detail, and while I was buffing off the wax, that I seductively applied by hand, and I mean sticking my hand in the Meguiars tub of wax and then massaging it in lovingly into the paint work, I hooked up an old water bottle and drained the SAAS AOS
That's 5k km of blow by "stuff", not bad for supercharged old girl with nearly 150k km on it
After smearing love and draining blow the car spent the night gallivanting around in the city, ended up at the girls, wasted, and slept out in the garden, it is now covered in 11ty thousands of pine needles
  • Like 1
I was talking with the guy from Craigs Automatics, who built my 4l60e, about going taller diff gears i.e. 3.07 or even 2.87, there recommendation was not to go any taller than the 3.46 gears that are currently in it because of the current converter specs, engine power and the 3.46 gears
He believes the current custom billet converter in the 4l60e is near on being maxed out reliability wise for the current rear gears and power the car is now making, which makes sense as the converter was originally speced when NA for around 500nm (currently around 900nm "ish") with 3.9 gears, he said that going any taller gears would probably overheat the converter and trans more than the current trans cooler can deal with and it would end up in tears, on the side of the road, he recommended that I just get some drag radials and be done with it 🤣
So basically taller gears will require a new converter, but, as I'm a "while we're in there kind of guy" that could end up down the proverbial rabbit hole of the T400 with overdrive that keeps popping up in my feed, and is also blindingly expensive
I'm also trying to find some new R888R in 275/40 17 to wrap up and stash away for the future, the current set on the rear are at about 50%, so probably about another 5k km away from needing to be replaced, it seems like I'll get about 10k km from a set of rears, but, currently I'm struggling to find any on hand anywhere, I have got Tempe Tyres to give me a stock alert for when they get some more in
While we are talking tyres, I'm heading into St George tyres tomorrow to try and grab some Mickey Thompson ET Street 275/40 17 to put on another set of 17 x 9.5 Simmons FR1's for special occasions.......yes, I know.......LOL
It's like a disease 🤪and car parts are the cure
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
