40 minutes ago, admS15 said:
f**k man, you have a real sickness. Et streets on 16's or even 15's will grip much betterer. Need that side wall big profile energy. Not sure if will look more or less bogan though.
I'm going 17" because I want to have matching rims, and 17" was the smallest size the FR1's come in, so comprises were made for the Bogan-ness of the FR1 life, it isn't optimal, but meh, it's going to be good enough for what I want
My old GTS-t Skyline made similar top end power to the Commodore, and got a 11.09 on ancient worn out 255/50 16 Mickey Thompson streets, and they hooked pretty good on the street in the dry as well, which is handy with a RWD car
Plus the Mrs will never pick the change, which is always a bonus
As for looking more or less bogan, impossible, the car is a old red commodore with gold FR1 Simmons, and I'm a old balding white guy with tattoos, so  I'm pretty sure I got bogan covered, much to my Mrs anguish
  • Haha 2
I has rubbers, build date was 0822, fresh stock, which is nice
Ordered the rims, they're getting machined for offset, I pick them up and get the tyres fitted tomorrow
Typically it has started to rain again so Wednesday night drags probably isn't on the cards
  • Like 2
Almost the ultimate bogan chariot but needs 2 doors for that title.
Get onto a suspension shop about a decent rear setup. That tyre can work with the right setup.
4l80 or 6l80 an option for you? t400 is getting hard to find now and decent internals
https://www.facebook.com/BrinksPerformance/posts/624930669420914
My current suspension will do for the 2 or 3 trips to the drags I do a year, the car is just a street cruiser with visions of grandeur
My old R33 only ever ran Bilsteins and kings and hooked OK on the Mickeys
As for the gearbox, there's a few options, but really, unless/until the 4l60e goes bang in a big way there's no hurry
Currently the trans is rated/guaranteed to 600hp at the motor, which it is roughly at now, Craigs have stated that it will still be fine though as they add in a fudge factor, they said it should be good for about 700hp, or 450kwatw but, that would void warranty and be on limited time
Fark, I keep blowing the main 60 amp fusible link
No reds at all, I just parked the car after returning from a drive, then tried to move it to wash off some dirt and nothing, no power at the ignition, no reds, no horn, no central locking,  no immobiliser, found the main 60 amp fusible link blown, so replaced it with the 60 amp ABS one to see what was going on, which brought the reds up, until I tried to start it, which then blew that fuse as well 😒
There's a short somewhere, I'll  need to jack up the car and look for the short, I'm hoping it's an easy "starter motor wiring meets exhaust headers" type of thing
Stupid cars 🚗 😒 🙄 😑 😤 😐 🤣
  • Sad 1
That sucks, I guess she doesn't want you to put those new tyres on her
FWIW, it won't be the starter motor via a 60A fuse, way too small, but headers (and anything else you've modified, which is almost everything now :p) would be the place to start.
Multimeter in the Fuse socket will probably confirm continuity to ground, and one option is to disconnect battery +, put 60A fuse back in and then check the regular fuses one by one to narrow down which specific circuit has the issue (I'm assuming the 60A fuse is in serial with the individual fuses like in sykline)
Yeah, but if it's enough current to pop the 60A fuse, it really shouldn't blow one of the smaller fuses downstream. I would presume that there's a significant short in the wiring between the 60A fuse and any other fuses downstream. Melted insulation is the obvious thing to look for.
But yes, pulling any and all downstream fuses, then probing in the 60A fuse socket looking for earth would be the best way to start. Hot tip - there shouldn't be a nice path to earth there!
1 hour ago, Duncan said:
It never ends
But it is expected with old or modified stuff
And it's not like it spends it's time in a garage coming out on sunny Sundays, the car is regularly used and abused, rain, hail or shine...well, rain and shine, I always keep an eye on the BOM for work, the car and bike is typically hidden away during major storms
I expect things to happen, nothing lasts forever,  and shit breaks when you lean on them, but, I'm happy enough because the old girl gives alot of joy, the car is fun as well..............😜
As for the new starter, I've still got some heat sheild left over from the job I did on the headers, I might look at making a cover like this thing > DCI-XT-5000-STR.thumb.jpg.836ec6b8b1a907e4a6410811e19de383.jpg
  • Like 1
    • True, might get it looked at. Found out you can in fact flatten the 12v battery relatively easily too the other day (kids lefts the hazards on) so meaning to get that checked in the new year. What's odd is it'll blow cold from both vents if you have the ac down as low as poss (18), but anything else the passenger one blows warmish. Also has been summer since I got it obvs but noticed it didn't seem to want to blow hot last night when we had a cold snap.
    • You ask for things. You specifically state you want responsiveness. A link was provided for a far superior, more responsive option. Find a MX5 workshop that will install it for you. Maybe MX5 Mania will throw on the Fab9 kit. It seems they want to charge almost 14K installed for their kit, so if they charge you $6K to install the FAB9 kit then you'll be ahead? Though really, the 2.5 with a 2860 running low boost will more or less feel as good as anything else. It's a lot of displacement and a small turbo. Think of a more modern RB26 with one stock turbo :p TBH, truth be told I've been driving my own car, and use about 50% throttle at most for 99.9% of the time. Mr Bogan is likely similar so this is all going to be semantics for the use case he actually has. (He'll be happy with anything relative to now) However, the EFR is hands down far superior in this use case. You really, really, really, really do notice it over the Garrett or equivalent.
    • You are correct, the earlier the torque, the earlier things snap
    • Gents, it will be getting the MX5 Mania kit and the 2.5 will be staying where it is My query was about the 0.64 or the 0.86, whilst the 0.64 might spool a bit faster, would the 0.86 be better IRT EGT and mechanical sympathy, with only a small difference in spool And as I assume I won't need alot of boost to get to 200kw, probably around 10 psi, and with max rpm at 6500, would high EGT even really be a issue with a 0.64 I'm heading into MX5 Mania at the end of Jan to discuss the install, so any info is welcome prior to that Basically have a chat and book a time so they can throw on the turbo kit, and fit a oil cooler with a thermostat, drive in drive out of course  In other news: just finished cleaning the car inside and out, it's now all ready to get covered in bugs and dirt driving to Goulburn tomorrow to lunch,  and go for a stroll along woolondilly River with the daughter and her boy, and of course, visit my grandcats and my new grandpuppy
    • Sounds like it has an actual problem with mode select doors, or something.
