We all know about them don't we? 🥲 -
By TurboTapin · Posted
Speedtek and manufacturing/QC issues go hand in hand. -
Unfortunately there is no way to properly access the baffles. It’s a welded unit and the inlets and drain are too small to jam anything down realistically. Same with the breather I took off the cover and foam and it’s basically a wall
I just want to double check this.... When you measured PTV, you measured it with the new roller rockers installed too yes? I kind of read the above as "we did PTV, then moved on to roller rockers..." I'm sure all is fine, but my brain is tweaking...
Shove more foam in it as a minimum if you possibly can. Or steel wool (not the stuff with soap on it!) Baffles / getting the oil out of the air is huge, and should be done at both the cam cover, and the catch can. I'm about to do a power steering reservoir, and even that needs some thought to make sure air is separated from the oil, to stop evil Cavitation. I'll probably look at doing my own catchcan later on too.
