On 5/7/2023 at 8:27 PM, Duncan said:
sorry Mark, I lied, it does get cold here.
<scottish> just had to walk home, uphill, in the snow </scottish
Have you thought about putting the washing machine inside so you're not also doing the washing in the snow? 😛
Just dropped the car off at Fineline to cut in the VN Group A bonnet bulge, they are going to see how it looks bolted and glued on first, then "maybe" mould it in, then back to standard height OEM engine mounts, the front Holden badge on the bonnet is also being removed and the locating holes welded up
Should be back to me in around a week
Which ever way Fineline do it it will be quality work, I've had alot of work done by them over the years on my cars and bikes, it has always been excellent work and paint match has always been spot on
Hopefully I don't hate it like the VK reverse cowl that was on before, the VK reverse cowl was too in your face, it lost the windscreen squirters, and was to boxy, the VN buldge is much more low profile and rounded which "should" suit the VX's rounded lines better, but, "failure is always an option when it comes to my good ideas"
Like this, only a bit more towards the front to keep the windscreen squirters and get clearance around the front of the blower and throttle body>
  • Like 1
Impulse buys away
So much for stock engine mounts, these have a larger softer bush than the Tuff Mounts, so less NVH that now, and are OEM height,.......... and are "apparently" unbreakable
Was recommended them by a guy at work who has been running them for years
Screenshot_20230524_215532_SamsungInternet.thumb.jpg.1b526163d846265b6eab08bc1689011f.jpg
Super happy with the result
Ample clearance to use OEM height engine mounts
I just need to put the Carbuilders premium under bonnet liner on to finish the "it's stock" look....... under bonnet 🤣, and fit the new engine mounts, then off to WSID for some more fun
20230529_161956.thumb.jpg.acd0f3e844142a7144de0d0cd98b16de.jpg20230529_161949.thumb.jpg.d29eddcc8a51371d88b94a48852d9fa3.jpg20230529_144030.thumb.jpg.35ce228393b0f0f146c5ee3bc0ff153e.jpg
  • Like 3
Gave it a wash and wax to clear a week or so of dust off it
All ready to drive down to Goulburn tonight to get covered in insects
I hate driving down to Goulburn at night, Kangaroos and Wombats, fair warning, get to your beds and off the roads
That actually looks pretty good Mark!
I'll be honest, I was curious how well it'd work on the VX bonnet!
The no badge on the front smooths it off too, but defeats the "it's stock" look a little. I guess you have to have some trade offs, right?! :P
I think for me, the only way you could make it look more stock, and a bit more streamline, would be to blend the bulge all the way to the end of the bonnet near the windscreen, and if it was still a little high, make the line of the windscreen edge "rise up" near it. But that's a lot of customising on a bonnet, for something that looks pretty darn good, and fits your purposes!
also, I'm not sure it needed a wash and a wax Mark, it was already the shiniest VX I've seen in a long time! Ha ha ha nice work on keeping her tidy, while also playing with mods!
  • Thanks 1
So, the new MACE unbreakable engine mounts are in, the engine is now back to standard height, the driveline-(read: engine/transmission/tailshafts/diff) are all nicely aligned again to the correct angles of the dangles
Everything fits nicely "under the bonnet", even with room to spare, driving back to work was a dream, no more NVH from hard poly engine mounts, and as was right in the world
Until..........I gave the beans hard
Harrop designed the blower to fit under the bonnet and have clearance everywhere, the top of the hat had heaps of space, and the rear belt drive had enough room to move up when the engine torqued, but........not when you add 10mm thermal spacers under the hat
What happened was the allen key bolts that hold the rear belt idler on, and a lip on the firewall met and had a issue with each other trying to occupy the same ground, thus war ensued as they both fought to hold the same ground, noisy screeching war, Mark got scared, backed off, and panicked
Apon inspection it seemed all good, maybe 10mm clearance between the allen key bolts and the lip on the firewall..... until you gave it the beans hard and the engine torqued up about 11mm to introduce about 1mm of the top of the allen key bolts to the lip on the firewall
Luckily, Tyson had the correct "firewall tuning" tools on hand for me to use, a big bent 3 foot pry bar, that convinced the lip on the firewall to move a little (probably 10mm) out of the way
So after careful tuning (you cannot really see where we tuned it), we had an ample amount of "no man's land" so that the waring parties would never again meet for hand to hand combat
Testing was conducted again by giving it the beans hard from various roads speeds on the R888R's with great success
Further testing will ensue as I'm going to try and hit WSID next Wednesday and see how it likes doing a big skid then getting stalled up on the foot brake and leaving hard on 275 Micky T drag radials on a sticky surface
Note to self: I must rummage around the workshops at work and find a typical tuning tool to take to the drags with me, if, on the off chance, any further "tuning" is required
Winner winner chicken dinner
How fun is it modifying 🚗
  • Like 5
Ground hog day
Spent "most of the day" giving the car a full detail, started by putting it on stands and cleaning the under body and inner guards, and wheels, then stripped off all the old wax, then washed and polished a few little micro scratches out, then "lovingly" applied some Meguiars Gold Class Carnauba wax, by hand, using the warmth of my hands to soften the wax then smearing it "lovingly" into the paint (probably weird, but it works so well)
After letting it cure for 1/2 an hour, enough time to clean and vacuum the interior, I buffed it off with about 10 microfibres, the paint looked excellent, I love the way wax gives that deep look to the paint
After it was all smick I stood back and bathed in all of it's heavenly glory
Then took it for a cruise, lovely day, car runs a dream, perfect.......until it started to rain on the way home
22 hours ago, The Bogan said:
Ground hog day
This is why I wash my car after it has behaved. Otherwise you wash it, want to drive it, and then drive it 500km through bugs and all sorts of crap.
(and/or just leave it dirty)
  • Like 1
@Kinkstaah
I was sent this as the table in HPtuner to look at
From your experience with HPtuner, if a tuner "tickled" this in 1st and 2nd to "lower power" a bit would it help??
Cheers
3 hours ago, Kinkstaah said:
Sent what. Nothing? (I don't see the thing to see :D)
LOL, I'm an idiot
This thingie, he said you can modify stuff in HPtuners to lower power in gears/RPM via timing
A little less power in the low to midrange of 1st and maybe 2nd won't be missed as it now just wants to overpower the tyres with anything more than around 50% throttle on street tyres and around 75% throttle on drag radials
If I could lose a little bit of power down low on drag radials to minimise wheelspin on drag radials I believe that would help my 60ft
Also wouldn't that help with mechanical sympathy IRT low piston speed and boost??, although, whilst my boost is only at 7 psi, it pretty much makes it just off idle, hence all of the torques it makes at around 2k RPM
What's your opinion on this table thingie?
Cheers
Yes you can. It removes timing given your car is setup with an Auto box (and presumably it is configured to use it) and came with it from the factory, so all of the wires match up. The car does a torque calculation in the ECU and uses it to determine whether it is going above it.
It will require tuning, so what the computer THINKS is X nm of torque actually lines up with how much torque is blowing the tyres apart. In other words, it is gonna be hard to tune this because you don't actually know what value you want in there, because your engine may think it is producing 342NM, but is actually producing 550nm, and 474 actual nm is when the tyres give way, if you catch my drift.
This will cost more than wiring in the TC system you have and work less effectively. I believe (my car is manual so...) this leverages the stock TC system in the car to change how it pulls timing to regain traction. Assuming that is all still connected and plugged in and working for your OEM car, it could be a feasible solution if you get all the data out of the logger to determine how to set this table (s) right.
  • Thanks 1
I just sent Autotech a email to revisit getting the RaceTCS installed
In the end, because of my lack of any wiring skills, and fear of burning the car down, if they cannot, or won't do the job, then I will need to revisit everything again
Wish me luck
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
