6 minutes ago, Ben C34 said:
I vote use racetcs thing if that helps.
Aftermarket ecu is more than needed here.
The issue is finding someone to install it for me
#menoskillz
Aftermarket ECU is not really needed for a LS, Haltech didn't do one for awhile given how effective things like HPTuners is. The only feature that I don't have access to is Wideband Closed Loop fuel control (which admittedly I do kinda wish I had!)
That said: I could also not require that if I just used the 102MM MAF's that exist and tune it via MAF like an OEM. The car is tuned well enough for me that that expense is a bit of ehhh, but if I had to start again and get new intake pipes made up etc etc I would have done that. I have full flex and all of those things. The underlying ECU is pretty damn robust.
Anyone that can install an ECU can install RaceTCS. All you need is to know where your ABS sensors are (there will be 4). And your injector wires are (there will be 8..) and where a tach wire is. Can be the engine ECU one or the dash one.
Splice into them, add power and ground and off you go. Though, it also requires some tuning to get it cutting in the way you want (i.e not too harsh/not harsh enough). Though you can use the dial.
Hell, I have the 6cylinder version, so only 6 of my injectors are spliced into. I assure you a LS cannot move under its own power running on 2cyl.
With no hyperbole, I am able to do a U turn in torrential rain fully WOT in 1st gear and it'll just ... do that. Though admittedly in that scenario it may splutter a little. I can also set it to 25% in some... off road.. testing... facilities and it'll just hold that amount of slip until the road speed catches up and then ends up going straight.
TBH it's also safe. Plenty of times I've been around the roundabout in the wet near my house, and the tiniest stab of the throttle will send the car going sideways at 10kmh if you don't have it, or back off before it kicks in from pure inertia lol. The LS is stable as hell once you're moving, but in my case I very much traded boost kicking in at 50kmh sending the car sideways with trying to get the car moving from 0kmh in some sort of stable manner. That mannerism with a positive displacement charger must be 'fun' but perhaps the auto dulls this somewhat at very low load.
  • Like 2
1 hour ago, Ben C34 said:
I wasnt very clear, I agree an aftermarket ecu isn't needed in this case.
English is fun. That sentence somehow perfectly works both ways!
MORE than needed, you can't even emphasize it differently and it still can mean:
it is more than is required
it is required more than merely 'needed'
In any case, this will ideally require a laptop and a bit of driving and a bit of skids to fine tune the behaviour. No matter what option you go with. The simplest way is right foot control. People just don't care in straight line world, they culturally ignore launching the car at low speed on road tyres. This is why Roll Racing exists, and everyone on a drag strip is using drag radials and a prepped surface.
Then they all tell themselves they are as fast as [insert supercar here] who is doing it on an unprepped surface with road tyres 😛
  • Like 2
New Hankook RS4 all round, it did take 3 months for the fronts to be available though
235/45 17 front, 255/40 17 rear
Whilst the 275/40 17 Toyo R888R were great/exceptional in the dry, and great value for money to boot, they really hated any standing water
Just cruising along and hitting some standing water at 110kph on the Hume would cause the rear tyres to not be team players
So back to the trusty old RS4's
#menoskillz
Would you be interested in picking up those skills? It's not hard, it's just a practice makes perfect thing and having good quality crimping tools makes an insane difference.
I feel pretty confident that we could talk you through what tools you'll need, how to get this bad boy wired up and tuned.
Honestly, I lack the confidence for this, me splicing into the ABS and injectors has my spidey senses tingling
In the end I'm happy to pay someone with the skills, knowledge and equipment needed to do it
Spiro and Travis from Autotech are looking over the instructions and hopefully they can get it done for me
Once people understand how the system works, and in conjunction with the rest of the car (i.e there's more considerations to be made if you try and splice this into a 2023 911 or M4...)... the stuff they need to do is pretty simple.
You don't actually even need to cut a wire. You just strip back the shielding. I did talk up about how much you want to tune it, but I am very OCD with this kind of stuff. I wanted my 5% to be 5%. In the real world if it doesn't cut enough with default settings you could just change the dial to make it more aggressive, i.e if it gives you too much slip (or not enough slip) at "10%" then just move the dial to 5, 0, or 15, or 20 for preference.
I just tuned the shit out of it so that I could leave the dial in one spot pretty much forever :D
  • Thanks 1
Well, the 255/40 17 RS4's have no hope in putting traction down when going past 25% throttle in 1st or 2nd, I've done about 200 km on them so far, so they should be "scrubbed" in by now
Whilst novel for the first 1 or 2 times, it is actually not really helpful when you are trying to take off with some "bravado", I've found myself needing to pedal "alot" more now than with the 275/40 17 R888R's, which was expected really
The voices in my head started saying to "get another........another set of 17 x 9.5 RF1 rims for some R888R 275's for the dry", my reply to them was "are we happy to keep swapping out rims dependent on weather conditions, we already do that if we going to the drags, and also have them packed in the car for extended trips away on the off chance it rains, and then explain to the Minister for war and finances why there's no room for her 3 suitcases when we go away for the weekend, because whilst the R888R's are great in the dry, they try and kill us in the wet", the voices in my head said "fark no....bring on the RaceTCS"
  • Haha 1
26 minutes ago, Duncan said:
didn't they make a 4wd commodore for a while?
.....reshell time!
They did, but no, some utes a wagon, and.......a coupe cross 8 with a butt ugly front end that no one really liked, plus they weighed alot more and put down alot less power than their RWD versions
Or there's this, there were heaps of these 4x4 conversions around when I was a kid, mainly Holden and Fords, utes, wagons and panel vans
b99f9d0a-45e4-4f93-9b8a-dccc1db0fe09-xlg.thumb.jpg.b4b3a0c5ba1c8766dbc2cecb12e7473b.jpg
Road tyres do not hook with powerful cars. They just don't. There is no road tyre that will. Shit if you launched on actual road racing slicks they probably still wouldn't.
This is why drag radials, dedicated tyres for this exact scenario (and only this scenario) exist. It's also why I scoff a bit when people talk about V8's being laggy in their delivery and "this cam won't provide grunt down low" that you see in V8 circles. It's like... what on earth are you talking about, as I struggle to maintain traction from a stop at 2500rpm and 50% throttle with my 'laggy, dead down low' cam.
And you boosted it with a non-centrifugal option, you DAMN ROOKIE!
  • Like 1
I believe alot of people only look at peak HP numbers, not the torque curves, and definitely not drivablility
They focus on peak HP on a dyno sheet
Also some build their street car engines to perform high in the RPM range with massive cams or turbos suited to racing at the track of strip, then complain that they are a pig to drive on the street because they have built out the response down low, fine if you can sit at the line on a transbrake or launch control, not so much when you want to take of quick from a set of lights
I'm glad I found SAU all those years ago, and although I've made some "poor choices" in the years after, the info I have gained here has limited the number of poor choices the voices in my head, or other internet experts from the Googles have advised is the "way to go"
10 points to SAU
Drove to Goulburn to visit my daughter
Goulburn has it all, wet, and cold
I'll probably be living here permanently in 2 years when I retire so I better harden up
Even with the wet and cold it still beats living in the Sydney suburbs though
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
