Hello chaps,
Im chasing some opinions. I have a 2000 Series 2 Stagea RS (Factory auto, Manual conversion), Currently running Nistune with flex sensor, making 332rwkw. The time has come to look at aftermarket ECU options, as i feel like i've reached the limit of what Nistune has to offer (could also be the fact that my tuner isn't really interested as he didn't build the car), and also to ditch the auto ECU. Now, i know most of you will tell me to buy what your tuner suggests, but i've ditched my current tuner, and now on the lookout for a new one, and the other good local options all offer tuning on the big brands.
I've been tossing up between the Link GT-T plug in or the Haltech Elite 2000 with harness adapter. My main requirements are Flex fuel, Boost control, Wideband control, Launch control, mafless, EGT monitoring and engine safety control. ECUmaster Black has also crossed my mind, but i don't see much local support.
Does anyone have opinions on the these 2 ECUs? If they are suitable? Other suggestions? all comments appreciated.
https://www.sau.com.au/forums/topic/480079-stagea-ecu-upgrade/
Well  I put a Link in my Stagea but apart from the usual functions I just used it for boost control although I believe it is capable of the other tasks that you require. .. but I believe top of the line Haltech will also do what you want.
Was yours an factory auto or manual?
28 minutes ago, GTSBoy said:
Yuh, they will both do the job (although I'm not speaking for the Haltech 2000 specifically. You might or might not need a different model).
But what is your plan for a TCU?
When you say TCU, do you mean Transmission Control Unit?
Mine was a factory auto but converted with GTR gearbox and rear end (I think GTSBoy missed the bit where you had converted to manual).
Ohhh. I only read "to ditch the auto ECU" and being part of the plan.
Ahh. Well, the TCU is part of the reason i want to ditch Nistune. Even with all the auto stuff turned off, i still get TCU/TCM error codes popping up from time to time.
Which link did you end up going with? a plug in or wire in?
Go the link. Easy to use and setup, help file is a lot better than haltech, use any sensor with its own calibration, closed loop boost and Wideband, upto 5d mapping, ethrottle if you want to enable other features like traction & cruise control and don't have to eat kebabs every time you drive the car.
  • Haha 1
Im leaning towards the Link. They've release the G4X range of plug ins now too.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
