  On 06/11/2020 at 1:48 AM, Lamsr334door said:
Interior looks amazing dude, the dash suits it so well, I've been tossing up with either an IC-7, microtech or AIM  dash, also where did you get the AC control unit moulding from, I like that location
overall was this an easy install and would you recommend it ? if yes could u do a quick run down of all the wires u spliced into n stuff, i want a dash for my 33 but I'm lazy as f**k with wiring ( do it every day with work ) and can never be bothered wiring shit on my own car haha
Expand
Lol i get it man. Its like all the landscapers with $h!tțy yards.
It took a bit to figure out the wiring and what all was need as the speedo converts some signals. Overall it was an easy task once it was all clear.
Scan thru this post. I posted a link on a how-to for the fuel sender.
Speedo wiring to the aftermarket calibrator/ charge light info is in here as well
You will have to wire the hi-beams/turn signals/e-brake/parking light directly to the units connectors (IC-7). I took pics of the back of my oem cluster which is used to find which wires I needed to t-tap into. Sorry I dont remember the colors of them.
The HVAC/shifter surround is from Garage Yoshida
  • Like 1
  • Thanks 1
I was curious  on wiring the the signals, hi beams, e brake, You just take a wire from the back of ic7 and then tap it directly into the plug off the cluster? I briefly tried it and it wouldnt illuminate on the ic7 dash, Is there something im missing?
Expand
Yes. Run the signal wires for those to the pins outline in the IC-7 instructions.
Make sure to push the pin lock open on the plug so the pins can seat all the way in.
  • Thanks 1
exactly, you literally just tap the correct wires at the dash because they all operate the way the dash requires, including the handbrake. (potentially excluding speed and fuel level sender as discussed above)
  • Thanks 1
Expand
Ok that was the issue wasn’t seated all the way, I Ran a test wire through but I can’t seem to find the the little deustch connectors, did the ic7 come with them or am I going crazy ?
  • Like 1
  On 03/04/2020 at 6:31 AM, Murray_Calavera said:
Sounds good. Fingers crossed it's only the charge light that I need to retain.
Expand
I’m assuming you’re referring the battery light (wire) on the stock cluster ?
Expand
The battery light in the dash cluster is the charge light. Have a read through the whole thread, it's been covered off already.
  • Like 1
  On 20/10/2020 at 8:47 PM, SLVRBAKSLPZ said:
I used the fuel sender value I found on HERE
I really didnt want to pull the sender out at the time. I'm curious to see your readings
On a side note you may need the Haltech GPS module to clock the speed correct for the IC-7. The speedo signal goes to the OEM cluster before the ECU which makes it a pain to get the speed correct.
Expand
So for the fuel level, it’s literally one wire to get it to work and it should self ground from the pump? No Matter how I configure it it does not work correctly anyone have any ideas ? I’m using the far left wire in picture for the fuel gauge
Expand
Gonna need the fuel level sender conditioner. Haltech makes one
On Haltech ECUs the signal wire goes into one of the AVI inputs
Expand
  On 13/11/2020 at 12:09 AM, Murray_Calavera said:
Haltech have just updated the IC7, you can feed the raw fuel level signal straight into the dash now if that's easier.
Expand
God damn it.... that would have been helpful when I did mine. At least I can swap it now and free up an avi for the haltech for the oil temp sensor
  • Like 1
  On 13/11/2020 at 2:30 AM, R324u said:
Yes I’ve tried to put it through the dash, just as the update but it does not do anything for me, idk I called haltech and they really didn’t help much either. Gonna have to keep messing with it
Expand
I wired mine up about an hr ago and it worked..
The the red/gray wire for signal (i used pin 18
The teal wire is the ground for pin 30
Make sure to select the correct channel for the AVI you used. And use 90-0 ohm
The you select the spot on your dash for the fuel level choose the AVI, not fuel level.
You still are required to adjust the voltage.
  • Like 1
Expand
Rt. I will keep both hooked up and see with one reads the most accurate. As of now I feel like the oem to dash is better.
My fuel level conditioner does a weird thing where it reads high then levels out after about 30secs. Im sure its something I can adjust in the ecu. The oem just reads the level instantly
Expand
Be interesting to see if tue oem to dash bounces around more while driving
Expand
I will investigate soon. I also have to see if my voltage setting are correct as well once I fill up.
  • Like 1
Expand
I was able to make some progress on it  last night by doing this just saw your post., I had to set the dash to default, what car are you using this on an r32?  I’m using pin 21/ 30 for the ground but those wire colors  you mentioned don’t match up to what I have so I’m guessing you have a diff chassis
    • Hi all,   long time listener, first time caller   i was wondering if anyone can help me identify a transistor on the climate control unit board that decided to fry itself   I've circled it in the attached photo   any help would be appreciated
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
