  • 1 year later...
Checking in on this. Got my IC7 fully replacing my stock dash. Emailed Haltech but they arnt getting me an answer I need. 93 R32 GTR Green/Blue wire in AVI 18. Red/Black grounded into 30 on the IC7 also spliced with ground from body so it's not so erratic for signal. 2 issues. 1st is when the cars not started the Voltage reads about 0.01 full and 0.29 empty. When car is on its changes to 0.19 full and 0.54 empty? Also any time I go over 3000 rpms ( doesn't matter which gear or speed ) voltages jumps .20 so gauge then drops to empty??
Edited by Hondakid90
Damn. I did not experience these issues when I wired straight to the IC7. are these changes automatically adjusting in the IC7 software?
hey mate,
im currently working on this now, i've set up a fuel level voltage so i can see the volts live (currently bouncing around 0.2 to 0.6 volts its very erratic) and im going to drive it till my car literally runs out of fuel. i have 2 jerry cans of e85 in the boot.
once empy will take a photo of voltage.
then i'll pour 5 litres in and take another photo (this will become my 0 litre value)
then i'll brim it and take a photo of voltage again.
This means i dont have to take anything out the fuel tank and my readings should be pretty accurate.
Will update this thread once i get my readings.
I barely use the car so it takes a while to empty a tank but i should only have about 5-10 litres left in it at the moment.
using this video for reference -
Edited by DaymoR32
And when I say my voltage is erratic this is me sitting in my garage at idle.
Wondering if one of them Haltech fuel conditioners will sort that out, or whether it’s an issue with wiring (have a relay running a thicker wire all the way to the fuel pump).
Edited by DaymoR32
Spelling
  • Like 1
Ok, I gotcha
So when I did mine, I didnt even program my IC7 display/check the fuel voltage. I just plugged the full/half/empty values in the IC7 for pin 18 fuel sender.
I have a conditioner as well. I really didnt notice if it cleaned up anything honestly. Even if you display 3 or 4 past decimals on the fuel level, you'll notice those numbers are erratic as well. I have it set to just on number after the decimal now for 17.2 gal
In your initial post you stated that gauge drops to 0 after 3000 RPM. Are you referring to the fuel level dropping?
That was @Hondakid90
i did about 30-40k's this weekend but fuel tank still has some in, hoping to do a bit more driving this weekend and fully empty my tank. voltaghe is still bouncing between 0.0 and 0.6v at the moment.
  • 4 weeks later...
I haven't been looking forward to this job but I can't put it off forever... Here is where I currently sit.
Handbrake, parking lights, blinkers, high beam and fuel level signal all straight into the dash.
Alternator exciter module - wired to switched 12V, charge light and my dash battery LED. This is the module I used - https://bluewireautomotive.com/products/alternator-excitor-led-warning-signal-module
Haltech GPS module - wired to switched 12V, ground and the factory ECU speed signal input. Haltech Pro plug in calibration, in the vehicle speed, calibration speed 60KPH, 5000 pulses per KM. The calibration was perfect right off the bat.
So, I originally planned to use the Dakota Digital SGI-100BT: Universal Speedometer and Tachometer Interface, to get my speed signal (the same way SLVRBAKSLPZ did) but I failed the idiot test and couldn't work out how to do it.
This is what I tried -
Into the SGI box I wired, switched 12V, ground, the VSS signal wire (pin 15) into the input and I tried every output into the ECU speed signal input.
The SGI box lets you send a test signal, when I did this the speedo moved and I thought I was on a winner. When I started driving however, there was never a speed reading. Playing with every output and setting within the device, I couldn't get a speed output. Clearly I wired it up wrong... The instructions are far from helpful and appear to be written for someone that doesn't need instruction. Have a look, I'll post them here.
So now the only thing that needs sorting is my power steering. The power steering is now permanently heavy which is a bit of a pain.
If anyone has any ideas about how to tackle the power steering, please let me know.
If SLVRBAKSLPZ wants to post up how he wired up and setup the SGI box, that would be amazing too.
  • Like 1
Is the purpose of the SGI box just to keep speed sensitive power steering? Because the ic7 and Plat Pro both run off the Haltech GPS, right?
I've been running without speedo input to the ECU for about 15 years since I removed the standard speed limiter (by cutting the speed wire :)), have only decided to add it back in lately when IC7 gained odometer function which is super useful for fuel planning in rallies. No idea why but I've never had a heavy steering issue (or maybe it's just heavy and I've never noticed because race car)
I originally bought the SGI box so I would have a speed signal to the ECU. I was pretty confident that the Pro plug in couldn't read the raw gearbox speed signal and I was planning to use the SGI box to convert the raw gearbox signal to a square wave signal that the ECU could read.
Yeah I'm surprised it doesn't come up more often when people are talking about deleting their dash. While I've been googling the issue, seems like the most common way it comes up is when people are deleting their HICAS ECU.
I'm hoping the solution is something as simple as, send constant power to the rack.
So i have a plat pro. I bought the GPS module for it only to find out it only work with e Elite as plug/play. I then bought the Dakota Digital box and it worked for me.
I did not have a heavy steering issue since installing the IC7 and speedo module
How'd you get the GPS module to read on the Plat Pro? when i talked to Haltech at the time they said I had to put a resistor in.
I also dont remember how I wider the speedo module but from your description it sounds correct. I know when I was just backing in/out my garage it wasnt reading speed. i wasnt til I actually went on the road that I started reading.
settings I used
settings I used
I wired the Haltech GPS signal output into the 2P / VSS ecu input - I think it's pin 16 on connector B.
In the ECU manager software, in the main setup inputs, I changed the following -
Calibration speed to 60 KPH and the pulses per KM to 5000 pulses.
I didn't touch anything else and the speed was 100% accurate when measured against my phones GPS speed on Google maps.
Shame you can't remember how you did your SGI box. I was driving around trying all of the different outputs on it, I tried a calibration similar to what your showing there... nothing. Speedo never budged when driving :(
Started with the easiest power steering fix first, popped a shim in the solenoid.
I'm happy with the level of power steering assistance with that setup so I'm calling it all done!
  • 4 weeks later...
Ok this is the final, final update (hopefully).
So as I had a V1 Haltech IC7, my internal pullup resistor built into the dash for AVI 4 was only 1,000 Ohm. Using this resistor, I had a working voltage range of 0 volts full to 0.0X empty (X as the value fluctuates too much).
Haltech updated their V2 IC7 to use a 240 Ohm resistor, the closest I could get was 220 Ohm so I used that. This gave me a working voltage range of 0 volts full to 1.6 volts empty. A huge improvement and I could have left it like this.
I thought that going to a 100 Ohm resistor might double my voltage range to about 0 - 3 V, so I gave that a shot.
It did improve it again, 0 volts full to 2.5 volts empty with the 100 Ohm resistor. I'm happy with this setup, the voltages are quite stable at this resolution.
And my dash communication extension cable came in so I've got that mounted on the dash now :)
  • Like 2
  • Thanks 1
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
