On 9/10/2020 at 11:06 PM, Tobz said:
Also would be interested in your voltage values for the fuel level
I still haven't gotten around to sorting this yet, but I will soon.
I didn't think I'd have any speed bumps other then the charge light =/ When I get around to doing this job, I'll pull the dash out, take the car for a drive and see what else breaks.
I'll post up the fuel level vs voltage table that I'll build as well when its done.
So this is what I’ve worked out that you need to sort if you replace the dash;
battery light
central locking control unit
interior light (I think the door light on the dash powers the interior light when you open and close the doors.
speed sensor
then the wires you need to add to connect to the new dash are the indicators, hand brake, high beam
Edited by Tobz
  • 5 weeks later...
I used the fuel sender value I found on HERE
I really didnt want to pull the sender out at the time. I'm curious to see your readings
On a side note you may need the Haltech GPS module to clock the speed correct for the IC-7. The speedo signal goes to the OEM cluster before the ECU which makes it a pain to get the speed correct.
  • Like 1
battery light
speed sensor
I have my IC-7 installed and I can confirm the interior lighting works w/o original dash
The IC-7 can display the battery voltage/set alarms so there's no need to wire for the light
And annoyingly, the IQ3 dash GPS is not available on the Haltech CAN, so you end up needing 2 GPS receivers :/
I have an R34, may be different?
And i think the battery light is wired in as an exciter for the alternator? Without it the alternator may not be charging your battery properly?
On my car we took the speed sensor wires from the Gearbox and then and spliced them into the wires going to the ecu, so we bypassed the dash.
Sorry just to confirm i used a GPS speed app on my phone to work out what 60kph is.
Then in the haltech ecu I went to the speed sensor page and hit the calibrate button when i was doing a constant 60kph according to the gps app.
Once that was done it was all calibrated and perfect :)
1 minute ago, Tobz said:
Just needed to calibrate it, which was pretty easy, got my phone out, did a constant 60kph on a straight road, hit the calibrate button, and now its perfect
Copy. So just the signal to the proper pin (53 on R33) at the ECU then ground (any ground)? Does the R34 VSS go to the dash first like the R33?
I may try this and see what happens. I really didn't want to GPS module for the possibility of it dropping out.
R34 GTT went to to the dash first. There are two sensor wires that leave the gearbox near the front cross member on the driver side. I cut those, then wired in some new wires, went up through the gearbox shifter and routed them to the ECU. There are two wires, they are non polarised so it doesnt matter which way they are wired. There is no ground.
Also sorry my interior light still works, but doesnt automatically turn on when u open the door. i think it ran off the door open light on the dash
Ok. I will try to mess with this over the weekend. I will still install the GPS just in case I have troubles.
So re-wire directly to the ECU, one wire to VSS pin 53 and one to 12v power on the ECU
there should be two pins for the speed sensor on the ECU.....
OK for the R33, 7 is the Tacho speed signal and 53 is the vehicle speed sensor. is the tac signal the 2nd pin? that the only other pin  i assume get spliced
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
