Hi, I just had my 25 neo tuned today on a apexi power fc.
The engine is stock except for 3"exhaust all the way and blitz fmic. I have a turbosmart manual boost controller, set at 10psi.
But after 4500rpm, the boost won't hold and lowers to 7psi at higher rpms.
Is it time to start searching for boost leaks? Or is there something I'm missing?
Thnx. Jasper
https://www.sau.com.au/forums/topic/480086-rb25det-boost-wont-hold/
I deleted the 2 stage boost solenoid. Incoming line to the turbosmart boost T comes from the turbo, and outgoing goes to the wastegate actuator.
Anyone else using only a manual boost controller and running 10+ psi?
I think something is not right, it should hold boost
You didn't mention the bleed - you do have the right one going to the actuator?
To test properly for boost leaks you need to make up a plug and put about 20 psi into it. Leaks are sometimes hidden from sight and hard to hear with the motor running.
3 hours ago, Jasper34gtt said:
The T only has one input and one output... In comes from turbo, out goes to wg actuator.
I think that's correct
OK so it bleeds to atmosphere. Is it supplied from a nipple in the compressor housing? Have you tried turning up the boost? I see the turbosmart instructions suggest removing the ball and spring in some applications - have you tried that?
Using the cold charge pipe as feed instead of directly from the turbo housing, shouldn't matter I think. But I'll try
From the compressor housing yes. I tried turning it up and stopped at 11psi. Then after 4500rpm it goes back to 7psi for some reason. I will try your suggestion to remove the ball and spring. Thanks
1 hour ago, Jasper34gtt said:
Just a thought... Could it be that the stock cat is too restrictive and exhaust gas pressure is pushing the wastegate flap back shut?
It could be blocked too. Either way I would either lose it altogether or get a better flowing one. If you can without outraging the neighbours  you could try dropping the exhaust altogether to see if that is where the problem lies.
Also, if dropping the ball and spring doesn't help you could pull the hose right off and , driving carefully so as not to overboost , see if the problem is with the wastegate.
But you would be very very wrong.
There is enough pressure drop across the shitty sidemount for that to be a bad idea. Although it should result in other bad effects, not low boost.
I'd seriously be looking for boost & exhaust leaks.
Look you should drop the cat as Kiwi said just to eliminate that as a cause, but it probably isn't. I've had completely blocked cats. The side effect generally is it is pathetically gradual to build to peak boost, makes jack power everywhere, but the peak boost is still usually up the rev range. Blocked cats generally do not cause a spike to peak boost then drop like you are explaining.
I think the problem is elsewhere, but do it just to check anyway.
Ok I will check the cat.
And as for boost coming from hot or cold pipe, I just installed it exactly the way turbosmart advised.
People do have good boost over the complete rev range with just a manual boost controller? Or do most people install a rb20 actuator? I thought I might give that a try... Maybe the wg spring is just too weak
22 hours ago, KiwiRS4T said:
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
