Hi, I just had my 25 neo tuned today on a apexi power fc.
The engine is stock except for 3"exhaust all the way and blitz fmic. I have a turbosmart manual boost controller, set at 10psi.
But after 4500rpm, the boost won't hold and lowers to 7psi at higher rpms.
Is it time to start searching for boost leaks? Or is there something I'm missing?
Thnx. Jasper
https://www.sau.com.au/forums/topic/480086-rb25det-boost-wont-hold/
I deleted the 2 stage boost solenoid. Incoming line to the turbosmart boost T comes from the turbo, and outgoing goes to the wastegate actuator.
Anyone else using only a manual boost controller and running 10+ psi?
I think something is not right, it should hold boost
You didn't mention the bleed - you do have the right one going to the actuator?
To test properly for boost leaks you need to make up a plug and put about 20 psi into it. Leaks are sometimes hidden from sight and hard to hear with the motor running.
3 hours ago, Jasper34gtt said:
The T only has one input and one output... In comes from turbo, out goes to wg actuator.
I think that's correct
OK so it bleeds to atmosphere. Is it supplied from a nipple in the compressor housing? Have you tried turning up the boost? I see the turbosmart instructions suggest removing the ball and spring in some applications - have you tried that?
Using the cold charge pipe as feed instead of directly from the turbo housing, shouldn't matter I think. But I'll try
From the compressor housing yes. I tried turning it up and stopped at 11psi. Then after 4500rpm it goes back to 7psi for some reason. I will try your suggestion to remove the ball and spring. Thanks
1 hour ago, Jasper34gtt said:
Just a thought... Could it be that the stock cat is too restrictive and exhaust gas pressure is pushing the wastegate flap back shut?
It could be blocked too. Either way I would either lose it altogether or get a better flowing one. If you can without outraging the neighbours  you could try dropping the exhaust altogether to see if that is where the problem lies.
Also, if dropping the ball and spring doesn't help you could pull the hose right off and , driving carefully so as not to overboost , see if the problem is with the wastegate.
But you would be very very wrong.
There is enough pressure drop across the shitty sidemount for that to be a bad idea. Although it should result in other bad effects, not low boost.
I'd seriously be looking for boost & exhaust leaks.
Look you should drop the cat as Kiwi said just to eliminate that as a cause, but it probably isn't. I've had completely blocked cats. The side effect generally is it is pathetically gradual to build to peak boost, makes jack power everywhere, but the peak boost is still usually up the rev range. Blocked cats generally do not cause a spike to peak boost then drop like you are explaining.
I think the problem is elsewhere, but do it just to check anyway.
Ok I will check the cat.
And as for boost coming from hot or cold pipe, I just installed it exactly the way turbosmart advised.
People do have good boost over the complete rev range with just a manual boost controller? Or do most people install a rb20 actuator? I thought I might give that a try... Maybe the wg spring is just too weak
22 hours ago, KiwiRS4T said:
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
    • Silly question, as I bet you've checked already, but the motor turns over by hand yes? I suspect Neil has a spare starter, though if not, I believe I have a spare R33 (or two) starter.
    • Yeah just run one of those posts to the Link like GTSBoy said. From google it looks like a "mishimoto boost controller" is a manual boost controller. Since you already have the link just buy any MAC valve and plumb it in where the mishimoto is now. Wires to the solenoid should come from the Link's / standard loom boost control wiring (I guess you have an r32, not sure if it is gtst or gtr, if it is GTR where is a 2 pin connector near the engine bay fuse box/injector resistor for that purpose, assuming the standard boost controller is gone)
    • No. The ECU's hose is for a connetcion between the plenum (assuming single throttle body, not ITBs) and the ECU's internal MAP sensor. This is the primary load measurement of the ECU - so you need to get this one right. This has NOTHING to do with the boost contol. The wastegate also needs to see a boost signal - but it is actually far better for it NOT TO COME FROM THE PLENUM (again, assuming single TB, and not ITBs). This should come from the turbo's compressor housing (assuming there is a nipple on there, which there might well not be), or on the boost pipe somewhere between the turbo and the TB. On the pipe from the turbo to the intercooler is usually most convenient. The boost controller is then located between that boost source and the wastegate, ACCORDING TO THE CORRECT PLUMBING DRAWING FOR THAT BOOST CONTROLLER. There is no general diagram or instruction that will be correct for every case. Then the other ports on the plenum are for purposes such as Duncan described. If the boost controller has an internal MAP sensor, for a boost display, etc, then it will want to be hooked up there, alongside the ECU and the FPR.
    • Ok gotcha, so one post to fpr  another to bov  and I have the mishimoto boost controller and a link g4+ so I’d just have the tuner set it up properly. For the last two from plenum post throttle to  ecu/ boost controller, I know that I have a hose coming from the ecu that I was confused about so I assume that’s what connect to the boost controller from the ecu? And then the last is just from plenum to boost controller then to wastegate?
