SeanR32GtSt Posted April 5, 2020 Share Posted April 5, 2020 Today I was on the dyno with new maf and injectors installed and right at the 280hp mark the clutch started slipping. I’m pretty sure it’s the oem clutch in my car. My question is, what’s a strong clutch with oem feel to it forbmy rb20 transmission? I found a stage one from spec found here. https://www.enjukuracing.com/products/spec-stage-1-clutch-for-rb20-rb25.html also does anyone know the name of the hose that comes off the upper manifold to the idle air control valve? It has a bend in it. When we were taking off the throttle body today the end of the hose cracked and fell apart so I’m also looking for a replacement one of those too. Link to comment https://www.sau.com.au/forums/topic/480093-clutch-recommendations/ Share on other sites More sharing options...
GTSBoy Posted April 5, 2020 Share Posted April 5, 2020 What country are you in? Link to comment https://www.sau.com.au/forums/topic/480093-clutch-recommendations/#findComment-7927954 Share on other sites More sharing options...
SeanR32GtSt Posted April 5, 2020 Author Share Posted April 5, 2020 6 hours ago, GTSBoy said: What country are you in? USA Link to comment https://www.sau.com.au/forums/topic/480093-clutch-recommendations/#findComment-7927971 Share on other sites More sharing options...
GTSBoy Posted April 5, 2020 Share Posted April 5, 2020 Well, in that case, a few truths apply; Buying expensive Jap brand name clutches for low power RB20s doesn't make sense. Most people on SAU are in Australia, therefor most of us would recommend an Extreme or NPC or one of several other local clutch assemblers. These are all Australian businesses, so it would make no sense to recommend one of them to you. Therefore you are reduced to waiting for someone in the US to make a similar recommendation on a clutch supplier in the states that they trust to build good clutches for Jap cars......or you widen your search parameters (away from Skyline specific info sources) and just look at who recommends what shops in the US for similar applications. Link to comment https://www.sau.com.au/forums/topic/480093-clutch-recommendations/#findComment-7927984 Share on other sites More sharing options...
Rusty Nuts Posted April 6, 2020 Share Posted April 6, 2020 There are a few thousand custom clutch builders in the USA for example Bully Clutch in California, you are not trying very hard mate. Link to comment https://www.sau.com.au/forums/topic/480093-clutch-recommendations/#findComment-7927995 Share on other sites More sharing options...
