Guest GR33DyMANGO
ive installed a few subs. just make sure u put a fuse between the amp and battery. when u turn it on for the first time...
MAKE SURE THE FUSE IS OUT AND DECK TURNED OFF DURING THE WHOLE INSTALLATION!
as a final step put the fuse in and turn the deck on..
ive had a bad experience connecting the whole thing with the fuse in... good bye amp :D
oh yer and make sure u use thick cable if you have a powerful amp otherwise the wire can melt which is really dangerous.
hope that can help:D
just a another tip as well...when you are grounding your amp, make sure the line between the amp and ground is as short as possible. also, the power line which goes to your amp should have a fuse within 30cm from the battery....just some things i have picked up from hanging around a qualified car audio installer
Guest Crazyfcuk
nothing but fluffly white stuff under there, actually come to think of it what happens if i get a puncture??? haha, na ive got a few of those short term tyre weld thingies in my car, havent had to use it yet (touch wood) so i cant really say if it will work or not, heres hoping it will
No probs with the wiring etc... 60 Amp fuse connected about 3" from battery, earthed to battery earth point on car etc...
i like the idea of buildouts from the odd shaped spaces on the sides of the boot. Will attempt the box re-build soon. No time this weekend though!!! WOOHOO!!!
Thanks everyone.
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
