hey guys a couple of questions
1. Would i be correct in saying that the Apex'i Power FC D Jetro version uses a map sensor instead of AFMs?
2. Is anyone running one of these at the moment? pros/cons?
3. For the guys who have build big power RB26s what brand pistions and rods have you guys used? And what would you recommend for an RB26 running twin garrett 3040s.
thanks heaps guys
anf
https://www.sau.com.au/forums/topic/48010-rb26-power-fc-forgies-etc/
cant help ya wth your first 2 questions, but as far as piston and rod brands go, with pistons you cant go too wrong with any of the "known" brands; JE, Arias, CP, ACL (Ross, re-branded), etc, i've had experience with all these and all have proved good, personally i dont like wiseco, i think their design is not as good as the others, but thats my opinion. As far as rods go Argo are good, Crower do a really nice rod, and well priced, Carrillo also do awesome gear. Probabley comes dowm to how deep your pockest are. But all of these, i've had experience with, and should take good power
dont need to win the lotto ive been saving for 3 years and ive had heaps of help from my old man and my uncles.
ive also had alot of luck so far with once in a life time deals when buying things for the car. only thing holding me back atm is which parts to use, not money.
im building a show/drag car, so the budget is really the last thing on my mind.
ive sacrificed alot of things to raise the money for this car.
i cant believe things are actually starting to happen :)
Guest two.06l
Hi anf
we have just done what u are starting, it was great, the pride and satisfaction of doing it yourself, in your own shed is worth all the pain. We are really pleased with how the car looks and runs. We used Aries pistons and had the skirts teflon coated and a cryogenic treatment done to all engine parts (to make stronger/last longer, mainly for drag). Rods? don't know/forget, and the engine builder is not here to ask. I can pm you a summary sheet of the things we have done to the car if you want?
Cheers, hope you accept advice/comments from a girl?
  • 1 year later...
It allows the removal of the Air Flow Meters which is particularly advantageous for large turbo applications such as the TRUST T88, HKS T517Z or twin GT3540's etc.... drag setups.
I've heard it also uses an ignition cut for the rev limiter instead of a fuel cut (which the STD Power FC uses) but I'm not sure if that's true or not.
If you want a Power FC for a road car I don't think it's overly necessary unless your idea of a road car to strap the biggest turbo on you can think of. For most people who don't upgrade the turbo or only upgrade slightly to keep good engine response and minimal lag, the STD Power FC will be sufficient.
apparently there arent that many people who can tune the d-jetro properly and it takes a shit load longer to tune.
im using arias pistons and REV billet rods with arp bolts.
also if your looking at getting an N1 oil pump you may want to just upgrade to a 33 gtr crank as the pump driver is smaller on the 32gtr crank
with those size turbo's you might be better looking at a stroker kit, HKS 2.8 - OS Giken 3.0l - Trust 2.7 litre kit, as a 2.6 with those size turbo's is going to have to be one hell of a revver to make use of the power band.
I also heard, yet again, that Apexi was no longer..... anyone else heard this???
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
