hey guys a couple of questions
1. Would i be correct in saying that the Apex'i Power FC D Jetro version uses a map sensor instead of AFMs?
2. Is anyone running one of these at the moment? pros/cons?
3. For the guys who have build big power RB26s what brand pistions and rods have you guys used? And what would you recommend for an RB26 running twin garrett 3040s.
thanks heaps guys
anf
https://www.sau.com.au/forums/topic/48010-rb26-power-fc-forgies-etc/
cant help ya wth your first 2 questions, but as far as piston and rod brands go, with pistons you cant go too wrong with any of the "known" brands; JE, Arias, CP, ACL (Ross, re-branded), etc, i've had experience with all these and all have proved good, personally i dont like wiseco, i think their design is not as good as the others, but thats my opinion. As far as rods go Argo are good, Crower do a really nice rod, and well priced, Carrillo also do awesome gear. Probabley comes dowm to how deep your pockest are. But all of these, i've had experience with, and should take good power
dont need to win the lotto ive been saving for 3 years and ive had heaps of help from my old man and my uncles.
ive also had alot of luck so far with once in a life time deals when buying things for the car. only thing holding me back atm is which parts to use, not money.
im building a show/drag car, so the budget is really the last thing on my mind.
ive sacrificed alot of things to raise the money for this car.
i cant believe things are actually starting to happen :)
Guest two.06l
Hi anf
we have just done what u are starting, it was great, the pride and satisfaction of doing it yourself, in your own shed is worth all the pain. We are really pleased with how the car looks and runs. We used Aries pistons and had the skirts teflon coated and a cryogenic treatment done to all engine parts (to make stronger/last longer, mainly for drag). Rods? don't know/forget, and the engine builder is not here to ask. I can pm you a summary sheet of the things we have done to the car if you want?
Cheers, hope you accept advice/comments from a girl?
  • 1 year later...
It allows the removal of the Air Flow Meters which is particularly advantageous for large turbo applications such as the TRUST T88, HKS T517Z or twin GT3540's etc.... drag setups.
I've heard it also uses an ignition cut for the rev limiter instead of a fuel cut (which the STD Power FC uses) but I'm not sure if that's true or not.
If you want a Power FC for a road car I don't think it's overly necessary unless your idea of a road car to strap the biggest turbo on you can think of. For most people who don't upgrade the turbo or only upgrade slightly to keep good engine response and minimal lag, the STD Power FC will be sufficient.
apparently there arent that many people who can tune the d-jetro properly and it takes a shit load longer to tune.
im using arias pistons and REV billet rods with arp bolts.
also if your looking at getting an N1 oil pump you may want to just upgrade to a 33 gtr crank as the pump driver is smaller on the 32gtr crank
with those size turbo's you might be better looking at a stroker kit, HKS 2.8 - OS Giken 3.0l - Trust 2.7 litre kit, as a 2.6 with those size turbo's is going to have to be one hell of a revver to make use of the power band.
I also heard, yet again, that Apexi was no longer..... anyone else heard this???
    • This was a huge help.  We followed the steps,  although shifting into 2nd was actually into 3rd for us,  and 1st was into 2nd ( steps 9 and 11) .  The long flash was the 4th flash.  So shift solenoid A is possibly the culprit.  Is this inside the transmission itself? Or is it accessible by just front the pan? Or is it bolted to the outside of the transmission?  Thanos for your help everyone
    • Can you enlighten me on your best practice regarding these hoses? I don't wanna make the same mistake if you already got a better solution.
    • I have some silicon hoses already, for example engine to watercooler. But yeah, I get the sentiment. The lower intercooler silicon hose is drippy too, despite not being very old. Does anyone except Nismo make these same lines out of rubber? Long term I think they'd be the better replacement, especially since the car won't live as hard a life anymore as in the past nor be driven as often.
    • I know most issues are just age related. But for example the turbo oil drains, there is dash adapters for these and you can just make a braided teflon line for them and (probably) never have them leak again. Also not terribly expensive. Can you even get the factory hardlines from new? Or are they repairable if they break?
    • I know it'd be much much easier with the tool. I hope I can find one that won't take 3 weeks to get to me an isn't a "Asian models kit" that has tons of (to me) useless adapters for a load of cash.   It's a summer project/fun car. I do wanna enjoy it, without endless downtime over and over. So yeah I would even go and buy an engine crane + stand to save myself the trouble of hard to reach or unreachable places going bad later on. Would also be a good opportunity to put on a Fluidamper, renew the mains seals and stuff like that. I have some money on the side that I can use for that, what I wouldn't want to or be able to do is let everything be done by a shop or have my engine completely rebuild right now. I intend to do most of the "doable" jobs myself. Pulling an engine can't be that hard, can it?
