Hi guys, so I had a go at taking my R31's (RB30) head off. Made sure to TDC and aligned the crank pulley with the markings, used a screwdriver in cylinder #1 spark-plug whole to make sure it was at the top of the stoke. Also took the rocker cover off to make sure the valves on #1 and #6 weren't open (turning the crank until neither rockers were moving) to know I was on the compression stroke. However, as per attached photo the exhaust valve on cylinder #2 and intake valve on cylinder #3 are open. All the other valves are closed.
Questions are:
1. Did I mess up TDC?
2. Could the valves be possibly stuck open?
Cheers for any responses, hopefully I didn't mess up too bad.
IMG_1341.HEIC
https://www.sau.com.au/forums/topic/480121-tdc-on-an-rb30/
HEIC file not all that openable. Try JPG or PNG or something. f**king phones!
I'm not sure you understand what is supposed to happen at TDC. Only #1 and #6 will be at TDC (when you're on the TDC mark on the crank pulley). One will be closed valve, because ignition point, the other will have the valves both open, because it is the overlap period between exhaust and intake, where the ex valve is very nearly closed, and the intake valve is opening. They will be nearly closed, but they will not be closed.
The other cylinders will be all over the place. Some valves will be closed, some will be open, reflecting the fact that one is on power stroke, one is on intake, one is on exhaust, and one or more are partway between (ie the ones at BDC are either at end of intake stroke or at end of power stroke).
Edited by GTSBoy
  • Like 1
https://www.sau.com.au/forums/topic/480121-tdc-on-an-rb30/#findComment-7928286
Cheers, that exactly what I needed to know. Was super confused because a mate had a head and all the valves were closed. Since this was the first time doing this I thought I must of mucked something up because it wasn't the same.
Edited by Anthony1016
https://www.sau.com.au/forums/topic/480121-tdc-on-an-rb30/#findComment-7928292
Questions are:
https://www.sau.com.au/forums/topic/480121-tdc-on-an-rb30/#findComment-7928295
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
