One big thing people leave out about e85 is the amount of fuel you use vs pump. I have done research and talked to people and for a street driven car to and from work and the shops it was way out. I get flex fuel and running a pump tune and a e85tune.
im still running 1000cc injectors, Steve thinks they will be done with water meth. I know for that 1000hp number e85 will most likely have to be used to get the bang going
Yep this is 100% accurate, you'd not want to run E85 to and from work.  The extra volume of fuel you need with ethanol goes up steadily as the blend increases, and that extra fuel usage impacts "just cruising" as well.   You definitely need a big fuel system if you want to make 550+kw on E85, though really if you want 550kw+ then you're probably a bit in denial if you think you can cut costs at this stage.   Block strength is potentially coming into question, OEM Nissan gearboxes are at the end of their line, the whole build has to be pretty serious at this stage.  Going a big fuel system when planning for 700whp+ on a smaller RB is pretty incidental in the grand scheme.
This still brings back the "but run flex fuel" thing, if you are aiming at commuting etc you probably don't want/shouldn't have methanol just sitting around in the car waiting for you to thrash it.  There is the clear bonus that you don't use it when you're just driving it normally, but then also you don't want it to get contaminated over time or even lose track of the level.  It's an extra thing you need to keep an eye on... the flex fuel idea again is one where you only put ethanol in if you want to get up to no good.  By E30 you have really good gains and the impact on fuel economy isn't actually that nasty by that point, if you want to get real fancy for an event then you can try and get it up to E50+ but you don't need to measure or think about it.
After that, keep putting normal pump gas in it and it'll gradually dilute itself down to E10 or less as you top up with pump gas and the tune will dial itself down to suit.   If you have a build that is going to make 550+kw on E85 then it's not going to be gutless on a pump gas friendly tune, and with flex you don't need to keep topping up the WMI, you don't need to do anything special.  Just drive the car and the tune will make sure everything is safe and well.    That's the kind of reasoning we've used at least :)
But yeah "for now" I'm sure if you can do the 550kw power level with pump and WMI and the 1000s  then it's at least a good stepping stone.
Gearbox, drive shaft and axles have already been swapped out for bigger and better items.
This tune is just that another stepping stone to the main goal. I’m not one to go all in at 1000hp and crash the thing. With each upgrade I need to re learn and get used to how the car feels. Once this step in done the final step will most likely be e85 and a full re work of the fueling system. Baby steps to get used to the power
  • Like 1
Sounds like a solid plan :)  Its going to be a monster as is.
  • 3 weeks later...
  • 3 weeks later...
  • 7 months later...
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
