Hey all I’ve recently decided to install a catch can and want to know if the setup I marked in the picture below is correct. So pretty much you just “bridge” the catch can between hose that goes from pre turbo pipe to the rocker cover?
Which catch can is also better - the baffled ones without the little air filter on top of it or the ones with the little air filter on top of it?
is a three port catch can really necessary? Because all it does is keep the oil out of the little hose that goes between both rocker covers? If i do go three port, is the setup marked on the pic correct?
finally, does anybody know the size of the rb25det rocker cover breather hose fitting in case I need to change the fitting on the catch can to match the rocker cover fitting. Thanks
3 minutes ago, KiwiRS4T said:
The first question is what is the function of your catch can and then the rest will follow.
But catch cans should not vent to atmosphere, should be baffled and at least 2L
Function is I want to keep oil out of my intake and intercooler piping!
So why isnt it good for them to be vented to atmosphere? All I can think about is that will be decrease pressure and cause a vacuum leak.
also by 2L do you mean a 2L catch can container? Does it really matter how much volume the catch can could hold, besides having to drain the oil less frequently with bigger catch cans?Thanks
Venting a catch can to atmosphere is illegal, if that matters to you. Having it plumbed back into the intake, the vacuum helps the catch can work better.
Venting a can to atmosphere won't cause a vacuum leak.
Some motorsport events require the catch can to be a minimum of 2L, I can't think of any other reason to use 2L other then more frequent changes as you said.
^^^what he said.  You want it baffled because that will help to ensure most of the oil stays in the can rather then get recirculated through the intake. Venting to atmosphere can also result in unwanted smells in the cabin.  And it works better if not vented. If you are not going to track it and you don't have a big problem you could have smaller  than 2L but be aware that some of the products you see on ebay turn out to be ridiculously tiny when they turn up in the mail. If you don't have a major problem then you can pipe both the cam covers in one hose to the catch can.
This is my personal set up... its a non return vented to atmosphere set up, which is the cleanest possible way for your engine. All of the returns and holes have been blocked. U can get -10an press fittings from Raw Brokerage and the elbows and such anywhere like amazon.
Wow, that went downhill fast. I haven't been on here much but really miss the respect.
Anyhow, for a simple connection just run a 16mm hose off the pigtail hose that goes to your inlet. Run some wire inside the short pigtail shaped hose and you will find a restrictor. Deleting the restriction is one of the reasons people have too much oil being sucked in to their air/oil separator. On a stock turbo too much oil fumes is not a problem. Once you add a bigger turbo obviously there is more suction, therefore more oil being sucked into the inlet, separator/catch can or not. The restriction must stay in place.
Connect this new hose to the inlet of your oil/air separator. Now connect the the outlet of your oil/air separator to the intake. Done. Hardest part is finding space in the engine bay. Also, notice the use of the words 'air/oil separator. Not catch tank.
Yes, I know people will roast you for not doing a search but we are all here to help. As my Old Man used to say, 'not asking questions is what makes you an idiot'.
  • Like 2
    • Hello, just just bought an 1999 enr34 with a stock rb25neo and I'm looking to upgrade the engine to 500whp I know some basic things but wondering if there are things I'll need to do to upgrade the stock block and all the bits and pieces to achieve this.
    • Thanks everyone for the replies and suggestions. Got the seats out (hoping I could find some existing grommets but no such luck). By tapping and measuring etc. I could figure out where I could drill through if needed. But first I borrowed an inspection camera and managed to go through factory holes in the chassis rail and could see that the captive nut was holding steady which is why it could retighten. So it was indeed a stripped section of thread, so I applied downforce by levering the bolt head with a screwdriver and went slowly back and forth until it came out. Camera helped a lot cos I could monitor that the captive nut was holding tight. Now I just have one very seized main subframe nut to tackle 😅
    • BOVs do have a purpose, if you ever log pressure before and after the throttle body, you will see a spike pre throttle on lift off from a WOT condition. Enough to bend throttle blades / damage e-throttle motors or simple assist in blowing off cooler pipes. FWIW, the above on really applies to those running at least 2 bar of boost. OP shouldn't have an issue, on the other hand, here are some videos of my shit box over a decade ago with some succulent dose with the airbox on and off. That shit box is unrecognisable these days 🫠
    • I've tried all different combinations of BOVs/ no BOV and stock bypass valves over the years, on gear changes the stock bypass valve seems to get the car back on boost quicker because in part the turbos wheel speed isn't being slowed down by reversion, although they have issues holding boost much over the stock setting. Most aftermarket BOVs you can adjust the spring, tighter will make it open later and close sooner, but in my experience it'll cause a bit of flutter at low load/rpm anyway. I've also got some input into this whole no bov causing turbo wear, never had an issue on any on my turbos HOWEVER, I got my R33 GTST with 200k kms on it, with from what I can see still has the original turbo, no lateral shaft play but has about 4-5mm of play in and out which to me seems like a worn thrust bearing from years (100-150k kms?) of turbo flutter running no bov, so maybe there is some truth to it in the long run. But that'll never stop me loving the Stutututu while I have the car.   OP just wants to know if he can run a atmo vented BOV with no major issues and the answer is YES, plenty of people do it, there's no harm in installing it and seeing how it runs before spending $$$ on an aftermarket ecu, last time I bought a Nistune it was $2400 for install and a tune , unsure of todays prices but you get me. Crazy money to spend just to fix the minor inconvenience of stalling that can be overcome by letting the revs come down to near idle before putting the clutch in or a little bit of throttle to avoid it. You're better off leaving the ecu and tune for after a bigger turbo/injectors have been installed to take full advantage of the tune and get your moneys worth.   Let OP have his Whoosh sound without trying to break his bank haha
    • I see you missed the rest of the conversation where they have benefits, but nothing to do with avoiding breaking turbos, which is what the aftermarket BOV made all the fan boys, tuners, and modders believe was the only purpose for them...
