brand new 49cc R1 racing pocket bike
Mine'sGTR
 Share
brand new 49cc R1 racing pocket bike in black (extremely hard to find).silver also
These bikes are extremely fast and stable. Comes with 2 ignition keys, electric start, built-in alternator, front and rear cross drilled disc brakes, twin exhausts with HPI coating, head lights, rear lights, brake lights and front and rear indicators, speed metre, fuel tank electric indicator, semi-slick tyres, with full R1 fairing and more! All stock is brand new and with immediate availablility!
R.R.P. is $2000...DON'T MISS OUT!!
Standard Specifications for this model
Engine Displacement/Type 49cc, Single Cylinder, Air cooled, high performance two stroke
Max Speed Up to 50KPH (after potential modifications speeds of 80KPH may be achieved)
Suspension Front and Back
Start mode: Manual and electric start
Fuel Capacity/range 1.5L/70KM
Fuel/oil ratio: 1 to 25 mixed gasoline
Brakes Front & Rear Disk brakes
Creeping capacity 15 degrees
Tyres 13 inch tubeless and aluminum wheel ( semi-slicks)
Gross weight 44 Kg
Fuel Unleaded petrol + 2-cycle oil (premixed 25:1)
Drive System Chain Drive/ centrifugal drive
Aesthetics Large variety of paint schemes available. Also included is a sponsor decal kit.
Controls Motorcycle style twist throttle/hand controlled brake levers
Frame/fairing High quality cast steel frame (chrome finished) and durable UV protected fairing
User Age > 16 years old
Maximum Load 120 kg
$1050
0423333023
[email protected]
 Share
    • That's true. However, this problem has started since the tuning. First time with the return journey from the tuning. But yes, the pipe was clogged with dirt and rust. That was certainly due to age
    • Great info @tidi0x  Will definitely be handy for others and maybe me if I decide to keep the shit box H pattern.
    • Bumping this up one last time.... I wanted to follow up on the clutch slave issue. I realized that what the issue comes down to is the pocket is flat milled, and the cylinder does not want rest flat. So in order to mount it correctly you will need to make a spacer for the fingers so the cylinder is floating. I took two plates of aluminum, drilled some holes and was good. I did still need to make the relief cuts in the bell housing, as even with the spacer the bleed section still interferes. The OE bell housing the mounting holes are raised from the housing.
    • If the event in USA goes ahead will be interesting as it seems the rules will get more cars over here. Apparently the track is laguna seca too. Yeah s15, if I get a the lower dash trims, centre console and change front cross member to standard LCA position will fit clubsprint. See how rules are as i would rather do complete widebody than a bolt on flare to run the 295 with proper clearance.
    • If the car is legal height I can't see it being an issue. Found a thread on reddit that might offer some insight.   I got a ticket from a copper in QLD for my S15 being too low. They had this wheel thing on a stick that they put under the car and it hit my exhaust. Anyhow went to an exhaust shop to get the exhaust tucked up/hung a little higher and I wound the coilovers up a smidge. Don't think I even had to go back to the police station unlike when I got defected for having a carbon bonnet when I brought the S15 from the ACT to QLD and had to replace it and then rock up at a police station and have a yougish female officer who knew nothing about cars confirm that I had changed bonnets. Should have just painted the carbon bonnet yellow to match the rest of the car lol
