Hello guys! I have r34 sedan wich came with rb20de in it. I swaped my engine and now I have est 300 hp .Unfortunetly I am stuck with stock open diff. Can anybody suggest wich cars locked diff will fit because I can't find parts in my area. I was only able to find one seller wich has this diff he doesn't know from wich car did this diff came from. It just says viscous lsd and and ratio 3.69 . If anybody can help to check will this diff fit my vehicle would be appreciated.
https://www.sau.com.au/forums/topic/480158-r34-swap-sedan-diff/
18 minutes ago, WR33KD said:
So your diff is the top pics and the new one you wish to buy is the bottom pics??
Yeah it should go straight in no problems.
Thank you for your answer your right . Can you please suggest are there other model nissan diff s that can fit
Have a look on the plate on your firewall and it will give the stock diff ratio for your car which I believe is 4.3 ...so  3.69 will be a lot taller - probably more than you want.
A viscous diff will not be much different from an open diff especially if it is old. To make a worthwhile change you need a mechanical LSD (I presume you don't really want a "locked" or welded diff).
Whereabouts do you live? You may need to search further afield to get a suitable diff.
  • Like 1
Thank you for your answer. Yes the ratio is 4.3. My mistake by saying locked diff I meant LSD. I live in europe under Russia. My country is called Georgia.
42 minutes ago, NOSTRADAMUSSS said:
It is pretty old
Um, they're all pretty old.
The first diff you pictured is not even from a Skyline. It is probably not even an R200. If it has 6 bolt (not 5 bolt as previously described) flanges AND is viscous, then it is more than likely out of a Z32, and could be an R230.
It's just the wrong diff everywhere.
The Laurel diff you show looks to be near perfect - so long as it is an LSD. Do not consider one out of an S chassis - there will be things that you can't handle - the ratio will be very wrong, the stub axles will be wrong and you won't be able to swap them between a VLSD and an open diff (as they are not the same lengths).
And lastly - you asked for a "locked diff". What do you mean? Just any old LSD? Must be mechanical LSD? The reason I ask is that VLSDs are weak. They barely offer any LSD action when they are old and when presented with a lot of power. Not that 300HP is a lot of power, but I got rid of my VLSD at that power level because it would just open up under load.
So to be exact this car is my daily driver. I dont want to weld diff. Because I want to keep it comfortable and safe on high speed turns and etc . . All I want is to make 2 wheels speen while trying to drift. So you suggest that there is no point in investing in old VLSD right? I am really confused, than what will be solution in this situation.
Edited by NOSTRADAMUSSS
My first tip is don't drift your daily.
My second tip, is, if you want to drift, then you need a 2-way mechanical LSD. A VLSD is a form of AIDS that you do not need or want.
You can buy a Nismo (or other brand) mech centre to put into your existing diff housing using the existing CW&P.
  • Like 1
Yep. Nismo diff is the answer here. The N/A R34 GTT has the same "stuff" as a S15, or at least a S15 helical bolts into a R34 N/A perfectly.
Luckily, a lot of people drift S15's so options are plentiful.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
