Hi everyone
I own a 1998 r33 sedan 40th anniversary that is currently running a 20e engine and drivetrain. I've brought a rb25det that comes with a r33 loom ect, I want to install the motor onto the 20e auto box will this work/last this will be temporary untill I have enough money to buy a 25det manual setup, I will be upgrading the radiator, putting in a trans cooler & will install a front mount intercooler.
Cheers looking forward to hear your feedback.
Edited by Mx5kyline
Oh that is cruel Nissan, putting 2l single cam in an r33.
I don't know how deep the troubles will be; wired in correctly the loom will cover the engine operation, but the gearbox is almost certainly electronically controlled and needs to talk to the ECU. So unless the AT control unit and ECU understand each other that will be a problem. It may be easier to go straight to manual
Also....this sort of thing always costs much more than you expect if you are paying someone,  because there will be a heap of unknowns you pay to fix by the hour. Don't start if your budget is tight already.
  • Thanks 1
Thanks guys, I've done a few big auto electrical stuff on cars so that's not my main worry atleast for now xD, my main concern was that 20e gearbox not lasting 1year or so, I guess there is alot of varibles on how I drive the car etc. I've done a few decent builds in the past that have blown out of budget by nearly double the original budget. Maybe it's best to for me to hold onto the motor and start collecting parts and also buying the manual conversion and smashing it all in at once.
Cheers for your help
Edited by Mx5kyline
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
