Trying to find a straight forward answer and see if anyone has had any experience with a 20det ecu in a plus T.
So I have a 20de ecu running in my plus T, stock injectors have been cleaned and a walbro 255 installed with adjustable fpr. It runs fine, boost fine, only on 5psi to be safe but looking to bump it up to about 7-10psi and was wondering if the red 20det injectors will work with the install of a 20det R32 ecu, I have found someone saying the timing is different and therefore will pre ignite etc. Surely someone has experience with this, my other option is a $130 speedlab chip for a plus T to run with red injectors.
https://www.sau.com.au/forums/topic/480187-rb20det/
8 minutes ago, Ben C34 said:
Oh sorry, I will try again. Yeah will work sweet. That's why every does it and reccomends it all the time.
Is that a better answer? May be the one you are looking for?
Bingo - you get the prize - that's the answer he was looking for !
But Nistune makes better sense ...
https://www.sau.com.au/forums/topic/480187-rb20det/#findComment-7928920
1 hour ago, Rusty Nuts said:
Have a read of these threads and make up your mind yourself, it will prevent more shit being thrown at you
Not sure what your point is Rusty. I didn't read all the way through but the main point is most people (except a fellow Kiwi I know!) used some kind of tuning device - power fc or emanage etc.  No one is saying that you can't add a turbo to a DE motor (although its not the best option) but rather that its difficult to account for different compression ratios, injectors etc without any means of tuning as the OP proposes.
https://www.sau.com.au/forums/topic/480187-rb20det/#findComment-7928925
1 hour ago, daninchainz said:
Nope asking if anyone has done it? no one deals with nistune in my area otherwise that’d be fine
Nistune tuners were hard to find when I started modifying my RB centuries ago so I had a guy modify an R32 ecu to suit but by now most tuners have come on board even though they would rather sell you a Link or a Motec. What is you nearest city?
https://www.sau.com.au/forums/topic/480187-rb20det/#findComment-7928926
Just now, daninchainz said:
Wellington region
OK my contacts are in Auckland, Tauranga and Christchurch but try a PM to Lithium  on this site and ask him if he knows anyone who will tune Nistunes in Wellington. You can buy the actual board direct from Nistune but they sometimes come up on TradeMe.
https://www.sau.com.au/forums/topic/480187-rb20det/#findComment-7928929
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
