NickER34 Posted April 21, 2020 Share Posted April 21, 2020 So I just got bodywork done my car as I had rust forming near both strut towers in the engine bay. I put the strut bolts back on and it dug into the paint and now I have bare metal exposed in the engine bay. What should I use to prevent rust from forming on the bare metal? I just spent a pretty penny getting the rust taken care of and I would hate to have to take care of it again. Anyone have any suggestions on what I should use to prevent this from happening? Link to comment https://www.sau.com.au/forums/topic/480205-rust-prevention/ Share on other sites More sharing options...
Murray_Calavera Posted April 21, 2020 Share Posted April 21, 2020 This feels like a trick question, maybe paint? Yeah I'm going with paint as my final answer. Link to comment https://www.sau.com.au/forums/topic/480205-rust-prevention/#findComment-7929206 Share on other sites More sharing options...
NickER34 Posted April 21, 2020 Author Share Posted April 21, 2020 Yeah I was gonna use a paint and primer I just wanted to be sure that I wouldn't mess anything up Link to comment https://www.sau.com.au/forums/topic/480205-rust-prevention/#findComment-7929207 Share on other sites More sharing options...
GTSBoy Posted April 21, 2020 Share Posted April 21, 2020 Yup. Paint. Any paint at all. KillRust would be a good choice, as it is a good anti-rust primer as well as colour. Link to comment https://www.sau.com.au/forums/topic/480205-rust-prevention/#findComment-7929208 Share on other sites More sharing options...
joshuaho96 Posted April 22, 2020 Share Posted April 22, 2020 Put some paint on it and a bit of soft vinyl as the sacrificial layer? Pretty common "mod" these days: http://www.garage-yoshida.net/daiko/ Link to comment https://www.sau.com.au/forums/topic/480205-rust-prevention/#findComment-7929225 Share on other sites More sharing options...
GTSBoy Posted April 22, 2020 Share Posted April 22, 2020 Might be a common mod, but it's not real good mechanically. A layer of adhesive vinyl (ie, clear contact) might be OK, because at least you're not adding something compressible into the connection. I certainly wouldn't want to put a disc of clear plastic with what looks like a 1.5mm thickness under the bolt head alone as a washer. That is not clever engineering practice. Link to comment https://www.sau.com.au/forums/topic/480205-rust-prevention/#findComment-7929233 Share on other sites More sharing options...
Greekos Posted April 22, 2020 Share Posted April 22, 2020 i would leave it as it, the torque from doing up the nuts will take the paint off no matter what you do touching it with some random shit paint will make it look worse. Link to comment https://www.sau.com.au/forums/topic/480205-rust-prevention/#findComment-7929249 Share on other sites More sharing options...
tridentt150v Posted April 30, 2020 Share Posted April 30, 2020 Hardened pennyweight/guard washers and grease....wipe away the excess after you are done. Link to comment https://www.sau.com.au/forums/topic/480205-rust-prevention/#findComment-7929923 Share on other sites More sharing options...
teddlon Posted July 21, 2020 Share Posted July 21, 2020 Applying a good coat of anti-seize product is a good method also. Link to comment https://www.sau.com.au/forums/topic/480205-rust-prevention/#findComment-7936548 Share on other sites More sharing options...
