Hey guys I have a 2001 series 2 R34 GTR and  the 4WD and ABS lights are on and I have no idea how to approach it. Car was running great up until one day I had a flat tire because a wheel cracked. Then I have replaced all four tires and hope it will go away but unfortunately it didn’t. I have tried the following methods but have no luck ?
-checked the consult port but there’s no cable wired in for pin 4 (probably because it’s just a base model and not a V-Spec) (see attachment)
-I tried looking at the trunk for the blinking red light on the attessa ECU (below the hicas ecu) but do not see anything.
-I checked the fluid level and it’s all good.
-I can hear the attessa pump kicks in when I put the car in accessories mode so I know the pump is definitely not the problem
-tried wiggling the TPS sensor (as someone suggested on forums) and no luck ?
-Tires are 265/35/18 and all at 35PSI
Any input will be welcomed! Thank you!
Edited by ggr34
11 minutes ago, ggr34 said:
Hey guys I have a 2001 r34 series 2 and I have the 4WD and ABS lights on and I have no idea how to approach it. I have tried the following method and have no luck :(
- checking the consult port but there’s no cable wired in for pin 4 (probably because it’s just a base model and not a V-Spec) (see attached picture)
any input will be welcomed! Thank you!
See if this helps:
Or this
31 minutes ago, ggr34 said:
Hey man I appreciate your help but unfortunately none of them related to my problem :(
? It looked like your problem was that you were trying to short out the wrong pins.
Check ABS sensors that lines up to ABS rings on all axles - happened to me a while back after done what you've gone through mine is R33 GTR, had same problem and somehow I decided to crawl underneath rear end for some reason I can't remember at the time (still can't remember now) and I noticed one of sensor didn't line up to ABS rings on rear left CV, pushed the CV back in the diff and problem went away.
Also, have a look at tyres and see if they all are the same, if one is slightly off, it'll do that, also happened to me.
  • Thanks 1
I’m pretty that’s the right pin. In order to get the attessa to display the error code you will have to short out the forth pin at top roll and the first pin at the bottom roll. As you can see in the picture I have attached, theres no cable going into the forth pin at the top. Correct me if I’m wrong
I thought the two links I supplied corrected you. Both suggest its two adjacent pins either bottom left or top right depending on orientation. And its certainly not the case that you have to have a V spec to do this.
    • Seemed to be good when Jeff owned it but they did a shit job on my car, probably worth a think before spending 10's of thousands of dollars where they might be cutting corners
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
