I have a set of 18" Crimson Inc Club Linea alloys rims for sale. They are 18 x 8" 40 fronts, and 18 x 9" 38 rears. The PCD is 5 x 114.3, so can suit Toyota, Nissan, Ford, Mitsubishi and others.
These fitted nicely on an R33 GTST, but will also fit many other cars. The rims are in good condition, and were repainted in a silvery bronze a few years ago. They include 4 centre caps. The front rims have R888r semi slicks fitted, but one is damaged. The rims are Japanese made, and good quality.
Rims are in Adelaide, and local pickup is obviously preferred.
Edit - forgot to add price - $600
https://www.sau.com.au/forums/topic/480210-parts/
I have a GTR style rear wing to fit an R33 Skyline. I don't think it's a genuine Nissan wing, but not 100% sure. It was on an R33 GTST series 2. The blade has been repaired - it split along the leading edge and deformed at speed (>240kph at the Bend). It was repaired by inserting a length of aluminium square tube and filling the entire blade with expanding foam - it is now much stronger than the original, and has survived many subsequent >240kph runs down the main straight at The Bend. The fibreglass is still a bit split on the edges, hence the 100mph tape, and the low price. It is ripe for repair & paint, and is a bargain at $50. It includes endcaps.
Located in Adelaide, and difficult to post so local pickup preferred.
Edit - added price $5020200422_111118.thumb.jpg.a0465f215e2a99e0d6fa73b2a253ce13.jpg
Edited by GeeDog
https://www.sau.com.au/forums/topic/480210-parts/#findComment-7929256
I have a pair of front upper control arms fitted with poly bushes, and a pair of castor arms off an R33 Skyline GTST S2. The control arms are already fitted with poly bushes (Superpro I believe, but whatever the purple ones are), so if your bushes are worn this is a cheap and easy replacement - way cheaper than new bushes, and you don't have to burn out the old rubber ones. The castor arm bushes are in good condition. Asking $40.
Edited by GeeDog
Typing error
https://www.sau.com.au/forums/topic/480210-parts/#findComment-7929257
I have a pair of Just Jap branded 20mm bolt-on wheel spacers to suit 5 x 114.3 PCD wheels with 66.1mm hub - fit Nissan, but may suit Ford, Toyota, Mitsubishi etc. These were on a Skyline R33, but will fit other cars. Wheel nuts are included - bolt these to your hubs, then bolt your rims to these to gain 40mm of track width. New price is $79 plus postage. Not very old, and nothing wrong with them - fix your stance for cheap.
Price is $50, local pickup only
Edited by GeeDog
Correction
https://www.sau.com.au/forums/topic/480210-parts/#findComment-7929258
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
