Hey RB26 guys!
Surprisingly, I can't find many recent turbo threads.  Everything seems to be from 2018 and older...
Anyway, I was wondering if anyone has had experience yet with the new Tomei turbos for RB26: http://www.tomei-p.co.jp/catalogue/t550b-rb26/
In due course, I'm looking to upgrade my stock twins, and am curious how these would compare to, say, a pair of EFR 6258, which they look the most similar to.
What are your recommended upgrades for a target of around 350-380 kw (500-ish hp)?   Reliability and (daily) drivability are my priorities, plus with very limited access to local welders (i.e. no one here does quality custom work like you can find in oz/nz or the US), it has to be fairly bolt-on so I can actually do it myself.
I intend to keep stock internals, and will do fuel upgrades with the turbo, and probably a stand alone ECU as well.  E85 not an option.   intake/exhaust a given.
Cheers!!
https://www.sau.com.au/forums/topic/480240-tomei-t550b-twins-for-rb26/
I think I know the repsonses you're going to receive here, so I'll go first. Never heard of them, but just looked them up. At $5000 - $6000 for the kit that doesn't make 600ps at engine it sounds like a huge waste of money. I don't think they'll come close to 350rwkw not running E85 as you have suggested.
From my findings these would not be in the same league power wise as twin EFR6258, but I'll doubt anyone on here in Oz is running these either for comparison. They are not a bolt on either. Full boost Geoff is the best one to give info on them in the EFR thread.
For what you have outlined as your aim for bolt on twins, no E85 and 350rwkw+ you're pretty much back to Garrett -5s mate. Even -7 / -9 seems to be better than these for outright power.
You'll have trouble finding any new info on new bolt on twin upgrades on here, as frankly very few people are investing in any new type turbo bolt in twin setups - Everyone is heading in the single direction for upwards of 300rwkw.
Dyno chart from their marketing literature, turbo barely came out a week ago:
Maybe it's the first halfway decent turbo Tomei has put out? From what I recall their ARMS journal bearing turbos were horrendous. Personally I don't buy those dyno charts, it's likely that it gives up some low RPM power to get more power at high RPM.
What confuses me is why the turbine trim is 82. That sounds like a very high number to me.
Edited by joshuaho96
  • Like 1
I think these are turbos that are competing with -9s and the HKS GT3-SS, it's shocking to me that power noses over even earlier than stock.
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
