Hi all
In the middle of assembling a dual feel plazmaman fuel rail with 6AN fittings to a standard RB25DET lower manifold and the centre 90 deg. -6 fitting is fouling up against the manifold. Theres no issues when i fit the injectors and the spacers are all at equal heights (they didnt machine the slots on the mounting tabs big enough either but thats a separate issue) so i was just wondering how others have gotten around this? Yea, i could just plug up the centre port and run it as a single feed rail but was pretty keen on the dual setup.
https://www.sau.com.au/forums/topic/480252-plazmaman-fuel-rail-issue/
How much is it fouling? If it's only a small clearance you need, then you can remove some material from the contact spot of the manifold.
Or, you could make some other sort of fitting there with the appropriate thread and a short length of stainless tube to take the AN fitting away from the contact spot. Welded together, of course.
I did think about that but just didnt know how much i could hog out before it affected the integrity of that water jacket it sits above of. It does foul a fair bit...but you know what, you just gave me an idea. The standard -6 fitting has a decent radius in the elbow so i think if used a -6 male to female swivel adapter instead that should solve my problem :)
Thanks mate!
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
    • Was that Australia Delivered Duncan? Does it have siren etc?   I used to have remote start on an old 32 two decades ago, it was a cool feature. I used to wake up early in winter for work. Start it and by the time i was out the door a few minutes later the engine was warmed up and the heaters had the car toasty. It was great.    I don’t mine the ambience lighting.  I drive a western star and it has footwell lights and ambient lighting and it’s great! From the pics of seen of them installed in a skyline I think it’s a nice touch
