Hi all,
I hope I've posted this in the correct location.  While not Skyline specific this is L series motor specific and I thought it worth sharing.  My long term home built and home tuned L28 stroker put down 201.6rwhp on the standard 48mm Hitachi SUs from a '71 240Z.
The set up could probably make a bit more power if time was spent further ironing out the needles and playing with the programmable ignition.  It's not crazy power but I think it shows that the old Hitachi's in combination with everything else can be underrated.
https://www.sau.com.au/forums/topic/480259-2016rwhp-on-hitachi-sus/
Nice.
I don't think anyone who knows what's what would ever argue that carbies don't make power. It's not as though it's difficult to get the mixtures right at peak power. Getting the mixtures right everywhere is the challenge, along with all the other niceties like idle, accel pumps, etc.
Carbs + programmable ignition is no bad thing at all.
  • 1 month later...
SU have a single needle of various taper. Only one part per carb.
I had run 45DCOE152s with 36mm chokes maybe ten years ago. Felt faster than the Hitachi SUs but I couldn’t tune out a lean patch And stutter (20:1 AFR) between the idle and main circuit. I was getting to the point really strange combinations of idle, main, emulsion tube and air correctors that started to impact the rest of the Tune.
Edited by neuby
  • 2 years later...
Hello all, sorry to bring up the dead thread.
I've been considering an engine swap or what to do with the L20A with dual SU's in my hako, any idea if it's worth getting the L20A optimised with the SU's and what sort of power it can muster, or should I just L28 it or the like?
What do you mean by "optimised"? Are you talking about just getting the carbies set up and tuned nicely, or are you talking about a high comp rebuild with porting and a cam?
The thing to remember is that the L20 is a very small NA 6 cylinder that can't muster a lot of torque. if you work it, you will be able to make a nice bit of extra power, but it will all be up high in the rev range and there will be even less torque down low (because of fat cam lower gas velocities through bigger ports). If you want to make a screamer, then yeah, work it, put a good set of pipes on it, tune it up, etc. But if you want to make a nice street engine then more capacity will always be the first option.
If your question is just about choosing between just tuning the carbies up or going for a bigger motor (which is not a very sensible question) then...... it will clearly cost a lot less to get the carbies done, and the result will be much nicer, but not in any way comparable to an upsized engine.
  • Like 1
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
    • Me coming to check the thread to see if my manual boost controller was set up correct......
    • Ah yes but were you responsible? In the time I've had it (just before Christmas) I spun off the track twice and drove into things twice, so four separate incidents.. in two outings. Luckily I have a full OEM GTR front end to put on which is hopefully not a precursor for further, future, more expensive mistakes to come. It is some consolation that anyone who would want to buy my Altia bar would have to paint it anyway, the guards, too. (if they can get over the asymmetry). Hopefully over the weekend I will disassemble and see how badly things are bent. From what it looks like, the headlight has actually just been pushed back and bent the headlight support (which .. somehow... crushed the guard in). I guess the headlight plastic is strong stuff.
