hey everyone. As stated in the title, is there a center ring that is suppose to be in there around the hub so it is flush with my rim? Someone at the shop says yes I need one. If not a ring, then is it fine the way it is? I'll order one if needed but what is it called?
https://www.sau.com.au/forums/topic/480263-r33-gtst-hub-centric-ring-needed/
Rb hubs are 66.1mm
Most aftermarket wheels are 73mm and you will need hubcentric rings. What wheels are you using? If they are off another Nissan such as a 350Z etc they will most likely also be 66.1mm
9 hours ago, KiwiRS4T said:
Rb hubs are 66.1mm
This is a picture of the rim.
Its just a plastic or aluminium ring that takes up the gap between the hub and the wheel centres to locate the wheel when you put it on. The wheel studs do all the work holding the wheel in place.
Yes, this could cause a vibration. In theory if your wheel nuts are tapered as most are the wheel will end up centered on the hub even without the right size wheel bore or hub rings, but if it is even slightly off the wheel will be offset to the centre of the hub and will not turn evenly leading to vibration that increases with speed.
10 hours ago, GTSBoy said:
If the bore of the wheel is larger than the spigot on the hub, then yes, you need a ring. It's not completely easy to see what's going on there, but it looks like there's no gap.
When driving at higher speeds a feel a vibration through my steering wheel that I'm trying to eliminate. So far I've replace tires and control arms on all 4 sides. Now I have to replace the rear wheel bearing. I'm hoping that eliminates it. Afterwards I'll take her on highway to see if it dissappears. They just mentioned it at a garage about the ring and I wondered if that had to do with the driving. If you guys say there is no gap then I won't bother touching it.
It is unlikely that the absence of a hub ring is causing the vibration.  More likely it will be either a tyre out of balance or related to the wheel bearing (Although thats less likely).
Diameter should be 66.1 on the car and the same on the rim or if it isnt you will probably find that it is 73.1mm.  As has been said, take the wheel off and measure it.
To answer your original question the name of the ring that goes around the hub is hub ring. EG:
https://au.gktech.com/hub-centric-rings-pair
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
