does any one have issue shifting from 2 to 3 ?
If i shift slowly it is fine but when flooring and trying to change quickly it doesn't normally go into gear. I heard short shifter makes it worse. Please advise.
I was thinking of buying below but tuner told me it will make it worse and wear the bushing .
https://www.ebay.co.uk/itm/CUBE-Speed-Short-Shifter-For-Nissan-Skyline-R32-R33-R34-RB20DET-RB25DET-RB26DETT/323789024509?hash=item4b63546cfd:g:1lkAAOSwgAJa2Ksc
Edited by drifter17a
https://www.sau.com.au/forums/topic/480281-gearbox-problem/
A gearbox with worn synchros will have problems shifting gears, generally 4 to 5 is worst but it depends how the box has been treated over the years
The faster you shift, the worse the crunch will be, potentially including missing the gear altogether. Short shifters help you physically move the gear selectors faster so yes they make the problem worse.
The only proper fix is to pull the gearbox out and have they worn synchros replaced. In the meantime, redline lightweight gear oil (smurf's blood), nulon G70 (or whatever similar is available where you are, there is no location in your profile and you didn't say) or even just heavier oil generally can help
https://www.sau.com.au/forums/topic/480281-gearbox-problem/#findComment-7930024
  On 14/05/2020 at 10:36 PM, GTSBoy said:
You need good circlip pliers and some pullers and stuff. The difficulty is "rebuilding gearbox diy", is being able to source the parts you need when you open it up and find 50 different things are f**ked.
Expand
Personally i get a specialist to do gearboxes, because the key point here is "50 different things are f**ked". Some problems would not be obvious to non-professionals. Obviously pulling apart and putting back together is just following a set of steps carefully, but there is no point doing all that and then realising you didn't see one or more issues.
https://www.sau.com.au/forums/topic/480281-gearbox-problem/#findComment-7930888
  • 3 weeks later...
I am thinking of putting redline heavy 75w-140 .
https://www.opieoils.co.uk/p-1023-red-line-heavy-shockproof-gear-oil-75w-140.aspx
reading online some say it is not good for my gearbox as it will be difficult to shit. currently have castril gl 4 75w-90.
tuner recommended this and looking online some people say it has fixed the syncro issue. My issue is from 2nd to 3rd and 4th to 5th if shifting quickly. I want this to be in box for a year or two before buying a recon one and replacing it.
I don't think lightweight or super lightweight work for me .
Spoke to redline and they said use MT-90 but again that is same as my castrol so think the heavy shockproof is way to go. has anyone used this /?
https://www.sau.com.au/forums/topic/480281-gearbox-problem/#findComment-7932263
If that oil helps you, your box is pretty stuffed. Redline website "NOT recommended for most synchro applications".
You're in a situation where you will have to try out something to see if it improves your situation. That said, if you need any other oil than what is supposed to be in that box, you are really only just covering up a problem that needs fixing.
https://www.sau.com.au/forums/topic/480281-gearbox-problem/#findComment-7932267
I have lightweight in my box. When it was first installed it would not shift with the engine running at all (with normal gear oil). Redline brought it back.
Of course, as a consequence of owning an ALFA for many years, I also know how to manage a baulky gearbox. Learning to drive properly >> bandaid fixes & snakebloods.
https://www.sau.com.au/forums/topic/480281-gearbox-problem/#findComment-7932269
If the synchros are on the way out some lightweight shockproof will help but only delay the inevitable. Don't shift quickly, double-clutch your downshifts. You will be able to get a bit more out of the transmission before rebuild. Don't try to DIY a transmission rebuild unless you feel like taking the transmission out multiple times. You will save a lot of money if you're willing and able to drop the transmission yourself, that's a good chunk of change right there.
https://www.sau.com.au/forums/topic/480281-gearbox-problem/#findComment-7932270
Expand
i take it your box was worn so it won't shift and redline brought it back ?
https://www.sau.com.au/forums/topic/480281-gearbox-problem/#findComment-7932271
Expand
new refurb one is around £1300 and want to kill this, buy one next year and then swap.
I can then rebuild mine and learn something . I can then keep as spare or sell it .
Have seen many posts stating to use lightweight but some other saying heavy weight. confused now.
https://www.sau.com.au/forums/topic/480281-gearbox-problem/#findComment-7932272
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
