does any one have issue shifting from 2 to 3 ?
If i shift slowly it is fine but when flooring and trying to change quickly it doesn't normally go into gear. I heard short shifter makes it worse. Please advise.
I was thinking of buying below but tuner told me it will make it worse and wear the bushing .
https://www.ebay.co.uk/itm/CUBE-Speed-Short-Shifter-For-Nissan-Skyline-R32-R33-R34-RB20DET-RB25DET-RB26DETT/323789024509?hash=item4b63546cfd:g:1lkAAOSwgAJa2Ksc
Edited by drifter17a
https://www.sau.com.au/forums/topic/480281-gearbox-problem/
A gearbox with worn synchros will have problems shifting gears, generally 4 to 5 is worst but it depends how the box has been treated over the years
The faster you shift, the worse the crunch will be, potentially including missing the gear altogether. Short shifters help you physically move the gear selectors faster so yes they make the problem worse.
The only proper fix is to pull the gearbox out and have they worn synchros replaced. In the meantime, redline lightweight gear oil (smurf's blood), nulon G70 (or whatever similar is available where you are, there is no location in your profile and you didn't say) or even just heavier oil generally can help
https://www.sau.com.au/forums/topic/480281-gearbox-problem/#findComment-7930024
3 hours ago, GTSBoy said:
You need good circlip pliers and some pullers and stuff. The difficulty is "rebuilding gearbox diy", is being able to source the parts you need when you open it up and find 50 different things are f**ked.
Personally i get a specialist to do gearboxes, because the key point here is "50 different things are f**ked". Some problems would not be obvious to non-professionals. Obviously pulling apart and putting back together is just following a set of steps carefully, but there is no point doing all that and then realising you didn't see one or more issues.
https://www.sau.com.au/forums/topic/480281-gearbox-problem/#findComment-7930888
  • 3 weeks later...
I am thinking of putting redline heavy 75w-140 .
https://www.opieoils.co.uk/p-1023-red-line-heavy-shockproof-gear-oil-75w-140.aspx
reading online some say it is not good for my gearbox as it will be difficult to shit. currently have castril gl 4 75w-90.
tuner recommended this and looking online some people say it has fixed the syncro issue. My issue is from 2nd to 3rd and 4th to 5th if shifting quickly. I want this to be in box for a year or two before buying a recon one and replacing it.
I don't think lightweight or super lightweight work for me .
Spoke to redline and they said use MT-90 but again that is same as my castrol so think the heavy shockproof is way to go. has anyone used this /?
https://www.sau.com.au/forums/topic/480281-gearbox-problem/#findComment-7932263
If that oil helps you, your box is pretty stuffed. Redline website "NOT recommended for most synchro applications".
You're in a situation where you will have to try out something to see if it improves your situation. That said, if you need any other oil than what is supposed to be in that box, you are really only just covering up a problem that needs fixing.
https://www.sau.com.au/forums/topic/480281-gearbox-problem/#findComment-7932267
I have lightweight in my box. When it was first installed it would not shift with the engine running at all (with normal gear oil). Redline brought it back.
Of course, as a consequence of owning an ALFA for many years, I also know how to manage a baulky gearbox. Learning to drive properly >> bandaid fixes & snakebloods.
https://www.sau.com.au/forums/topic/480281-gearbox-problem/#findComment-7932269
If the synchros are on the way out some lightweight shockproof will help but only delay the inevitable. Don't shift quickly, double-clutch your downshifts. You will be able to get a bit more out of the transmission before rebuild. Don't try to DIY a transmission rebuild unless you feel like taking the transmission out multiple times. You will save a lot of money if you're willing and able to drop the transmission yourself, that's a good chunk of change right there.
https://www.sau.com.au/forums/topic/480281-gearbox-problem/#findComment-7932270
i take it your box was worn so it won't shift and redline brought it back ?
https://www.sau.com.au/forums/topic/480281-gearbox-problem/#findComment-7932271
new refurb one is around £1300 and want to kill this, buy one next year and then swap.
I can then rebuild mine and learn something . I can then keep as spare or sell it .
Have seen many posts stating to use lightweight but some other saying heavy weight. confused now.
https://www.sau.com.au/forums/topic/480281-gearbox-problem/#findComment-7932272
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
    • Plan on the day will be to park trackside. Depending on space availability we will try put a small shade tent and a few of the cars on top of the hill inside turn 3, this is an easy to get to parking area with views of Turn 2, Turn 3, Turn 4 and Turn 5 and limited other pieces of the view around the track. IMPORTANT NOTE! One consideration from previous years is from memory the trackside parking sells out before the admission tickets, for that reason I encourage anyone planning on coming to buy tickets for parking now via the official website; https://www.worldtimeattack.com/ The type of parking you are looking for is 2 Day Park & View (Access Around Venue) Vehicle Pass Only Please note this does not include admission to the event itself, remember to grab that also, and kids under 12 get in for free!
    • This is going to be a mid week evening cruise. Come along and join us for a drive out to Palm Beach. This is a change of event plans after talking to some of the older members of the club. SAU NSW is planning on hitting Old Pac again shortly, stay tuned for details. When: Thursday 26th of June Time: 7:30pm meet/8:00pm departure/10:00pm finish Meet: Spit West Car Park / Spit Rd Mosman NSW 2088 Destination: Palm Beach Public Parking / 16 Ocean Rd Palm Beach NSW 2108 Up to date information as always can be found on the events page of our website, the link for this event is https://www.saunsw.com.au/events/palm-beach-cruise There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our track days. This is an official SAUNSW event and will be run under a Motorsport Australia permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU:NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave. Thanks guys and hope to see you there!
    • Good time for a carbon roof
